1981 F 35 -- liftable keel stuck
Posted by laurens visser (laurensvisser@…>)
Hi All,
I have recently purchasedFreedom 35 - Fairways Marine UKyear 1981 - Nr:120
She was located in S France, now lies in Ymuiden, HollandMy question is about the liftable keel/sword of the boat: I took the keel up for the transport of the boat, but can’t seem to get it down anymore now. I don’t think it is due to dirt or waterpocks looking from under the boat.
Has anyone faced similar problems?
kind regards,
Laurens Visser
Do you Yahoo!? Yahoo! Search presents - Jib Jab’s ‘Second Term’
Posted by petercschaefer (petersch@…>)
Hi Laurens,
it probably helps to remove the lid of the centerboard case inside the boat. On
my
Fairways F35 there had a lot of screws to be removed and the lid be carefully
lifted at its
forward end where the stainless tube passes through. After that the centerboard
can be
inspected from above.
I hope this is helpful.
Peter Schaefer
Posted by Manrique Feoli (manrique.feoli@…>)
Hi,
I agree I would definately open the lid and check, you will find two wooden
blocks that may be in a wrong possition, or you may have some kind of jam or
an object stucked in the way.
-----Original Message-----
Sent: martes, 01 de febrero de 2005 12:53
Subject: [freedomyachts2003] Re: 1981 F 35 – liftable keel stuck
Hi Laurens,
On my
carefully lifted at its
centerboard can be
Peter Schaefer
Yahoo! Groups Links
Hi, this was indeed the way to do it
Problem solved in the meantime
tx vm all
regards,
LaurensManrique Feoli <manrique.feoli@…> wrote:
Hi,I agree I would definately open the lid and check, you will find two woodenblocks that may be in a wrong possition, or you may have some kind of jam oran object stucked in the way.-----Original Message-----From: petercschaefer [mailto:petersch@…]Sent: martes, 01 de febrero de 2005 12:53To: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: 1981 F 35 – liftable keel stuckHi Laurens,it probably helps to remove the lid of the centerboard case inside the boat.On myFairways F35 there had a lot of screws to be removed and the lid becarefully lifted at itsforward end where the stainless tube passes through. After that thecenterboard can beinspected from above.I hope this is helpful.Peter SchaeferYahoo! Groups
Links
