Brian:
A belated hello. Saw Cayenne Saturday heading south from Annapolis.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Brain GuptilSent: Monday, October 23, 2006 1:25 PMTo: freedomyachts2003@yahoogroups.comSubject: RE: [freedomyachts2003] 88 Freedom 30 Mast
Rees
All I can say is do the math or come over and try and remove MY masts. The disk that the mast sits on is about 2 in height and 16 in. in diameter, very rough estimates. Thus, the area available for a epoxy bond is roughly 180 square inches (3.14 times radius squared). IN order to release, the bond must sheer. I have two masts that will stand upright without touching the deck hole edge, when the deck compression ring is removed, thin in 15kn of wind. I broke 5/8 in line trying to pull them. I bent the goose neck fitting trying to twist the mast loose using the boom, I mean my crew did when the kept pushing after I had told them to stop.
I hope I NEVER find the person who did this to this boat.
Your choice!
Brian
Brian Guptil sailordude@brigup.com
2501 Boston St. Slip-536 www.brigup.com
Baltimore, MD 21224 206-818-3203
S/V Cayenne is moored on C dock.
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Rees MidgleySent: Sunday, October 22, 2006 10:49 PMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] 88 Freedom 30 Mast
Brian,
I don’t think this has to be true. A man who helps to maintain our Freedom in the BVI previously worked for 15 years in the Freedom factory doing all aspects of construction. Later he managed a Freedom charter business. He said I could drill a hole a few inches above the bottom of the mast and pour a pint of epoxy into the hole. This would form a casting on the inside that would be about one-half inch high. This stops the mast from moving sideways and making the sound. He said the mast could still be removed. He said it was critical to avoid using too much epoxy, presumably to avoid contacting the bolt that prevents the mast from revolving. I don’t recall the details but it may be that he would have pre-coated the inside of the base of the mast in some fashion before adding the epoxy. My guess, however, is that it might be more difficult to re-install the mast after removal.
- Rees
On Oct 22, 2006, at 6:43 PM, Brain Guptil wrote:
Fargo and Chris
Gentlemen, I caution you, if anyone suggests poring epoxy or resin in the ware exit hold at the base of the mast so as to “glue” the base, it is true that the mast will not clunk, but it also WILL-NOT COME OUT when so desired, without the use of a SAWS-ALL or other such tool.
Brian
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Fargo RousseauSent: Sunday, October 22, 2006 4:48 PMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] 88 Freedom 30 Mast
Oh Chris:Well, I made the same discovery in the middle of the night, sailing down the Chesapeake in a storm. Very upsetting…as you know… but…NOT TREATENING. The mast is very strong at the base…and elsewhere…and the mast step is also very strong. We have sailed and motored 4,000 miles since the first Klank…First… how much does the mast move? Mine moves about 1/16th to 1/8th inch… in a deep roll…no sails up. When it moves it emits a solid clank…and you can feel it all over the boat. I began to relax when I saw a Freedom owner’s commenta few days after my discovery… “I know all is right with the world when my mast goes, KLANK”. There is a fiberglass molded plug mast step hidden inside the mast base…with a deep slot down the middle …aligned with the keel. The bolt you see at the base of the mast lays down in this slot… This bolt system is used solely to resist mast twisting torque…and not to “bolt down” the mast. The mast is actually held in place by the urethane rubber wedged in collar up at the cabin top. There are a number of “fixes”…ranging from…getting used to the sound…to unstepping the mast and enlarging the base plug with tape…Will help further if you like…Dennis Paul is the expert on this issue…and will probably unstep my mast this Fall and set it up correctly after some deep service on mast items… wires, etc…Best wishes,FargoF30#12chris <watts2434@yahoo.com> wrote:
Ola,Just bought a 88 Freedom 30 and at the mast step inside the boat at the very bottom, everytime the boat rolls from side to side, something large clunks back and forth, like its loose or broken off! :-0 not sure how the mast is put in place down there, any ideas or is this normal?/
