Hey all, This question is not about a Freedom, But I know a few of you here have loads of experience with other make of boats as well.
I have a renovation project with a Helms 24. I removed the plate that holds the mast into the step to rum some new wires. I found an application of some material
that surround the are where the plate fits into the mast tube that is very hard and was obviously cast and hardened into the area to “Seat” the plate so the it fits the mast better. Can anyone tell me what that material is or what its called so that I can get some and finish up my mast project.
Your help will be very appreciated!
Thanks!
“still buried in 5 new inches of snowfall in NY”!
Randy
Spartite?
It was gray colored, Hard and brittle- like stone
harder than concrete though. Maybe it was Portland cement?
I suppose Spartite would work. All I need is 4 ounces though.
Thanks for the thought Geoff.
I’m confused. I had a Helms 25 (many moons ago) and I think that the mast was permanently attached to a deck plate and the mast was deck stepped. Again, this was a long time ago so I could be all wet. Maybe photographs are in order…
