Has anyone solved the problem of easy access to shut off the
aft head seacocks when leaving the boat on a Freedom Hoyt 32??
Currently I have to get into the cockpit locker – no small
feat for the less nimble! I am contemplating cutting an access panel behind the
head – anyone have ideas? Thanks
I have done that. I put in a 12X12 teak door as an access panel Swardron barr <rwhb@…> wrote: Has anyone solved the problem of easy access to shut off the aft head seacocks when leaving the boat on a Freedom Hoyt 32?? Currently I have to get into the cockpit locker – no small feat for the less nimble! I am contemplating cutting an access panel behind the head – anyone have ideas? Thanks Ron Freedom 32 Newport RI “Life is a Reach, then you Jibe” SWARD
access panel
Sward
I thought they all had access panels behind the
head. Mine has one that is about 6" x 12" which
allows one to reach in and shut off both
seacocks. Should be fairly simple to install.
I’ll take a picture of mine and send it to you if you would like.
TW
F32 Anoush Koon
Ron
Freedom 32
Newport RI
Checked by AVG Free Edition.
Version: 7.5.485 / Virus Database: 269.13.12/997
Release Date: 9/9/2007 10:17 AM
Version: 7.5.485 / Virus Database: 269.13.12/997 - Release Date: 9/9/2007 10:17
AM
TW
F32 Anoush Koon
Ron
Freedom 32
Newport RI
AM
