I installed a vertical Muir on my 32 about 4 years ago. Despite some
glitches I absolutely love having it.
I can give you my one absolute bit of hard-won knowledge: Do whatever
you can to place the windlass as far forward as possible so the drop
from the windlass to the chain locker will be as straight as
possible! MAKE THE DROP VERTICAL, if you can. You might not be able
to, there’s some conflicts from the fitting at the base of the
jibstay on deck and also a plywood diagonal stiffener underneath in
the center of the chain locker. Mine ended up just barely aft of the
door to the forepeak with a quite steep, but not vertical, pipe for
the rode. That’s the one difficulty I have with mine: despite that
very steep “feeder” pipe between the windlass and the forepeak it is
hard to get a rope rode to reliably feed down the pipe and into the
forepeak automatically. Chain always works fine because of its
weight, rope will usually clog up in the pipe without some help.
I’m vaguely keeping my eye out for a good deal on chain and I’ll get
a bunch of it, 100 feet or more, when I find it. I like a nylon rode
and despite all that weight in a very bad place on the boat, a
definite negative, it is just so much easier to use chain with mine
that I’m sure I`ll end up with (nearly) all chain someday.
I’m not sure you’ll be able to use the original chain pipe or that
you even want to. I think the windlass should probably be installed
in line with the bow roller, but your mileage may vary. Any
windlasses will almost certainly have its own chain pipe anyway. My
original chain pipe is now used for a pull-out hand-held remote
control for the windlass. One day it will also contain a pull-out
hose for a deck wash pump, but that hasn’t happened yet. I mounted my
windlass about in place of the original large bow cleat and moved the
cleat to starboard beside the windlass. The rode gets taken off the
windlass and placed on the cleat once the anchor is on the bottom.
Some totally random details I`ve learned over time: In a bouncy
anchorage the “foot” switches are often actually “knee” switches, you
have to crawl around just to hold on sometimes. I’d like to say I
knew this ahead of time and sagely placed mine accordingly, but the
fact is I just lucked out. Crawl around a bit when you’re deciding on
the placement of the switches and see if you can still tail the
windlass if needed while mashing the “up” switch with your knee.
I’d plan on both “up” and “down” foot switches for the windlass, even
if you get a free fall windlass. I only had an “up” switch originally
but I changed to both. (When weighing, I occasionally have to reverse
the windlass momentarily to clear a minor chain twist and this takes
just a second with both switches but was a giant pain without
the “down” switch.) I actually have 3 switches available: the hand
held remote, the foredeck foot switches and also an up and down
toggle switch at the helm. The hand remote is a bit superfluous now
that I have the “down” foot switch but I very strongly recommend
installing a cockpit switch. With crew, someone will just use the
foot switches, but single handed the cockpit switch is invaluable.
Single handed, I use the foot switches to get to a very short, nearly
vertical (and all chain) scope then, after a leisurely stroll to the
helm, I use the cockpit switch for hauling the last of it off the
bottom. I listen for the big “clonk” of the anchor going into the bow
roller and just drive or sail away, [yawn]…, nothin` to it (to be
completely honest, I feel a little bit smug every time.) The cockpit
switch also greatly simplifies setting the anchor single handed in a
blow or a current. I can be at the helm and use the throttle and
wheel to hover over the exact spot I want and let go of the anchor
from there. I drop some extra slack in the rode, stroll to the bow
while the boat gathers some sternway and I snub it off on the bow
cleat. I almost can’t miss. For $20 of wire and a $4 switch, I think
this one’s a no-brainer.
I can continue to ramble, I suppose, but do you have specific
questions? I’d also be happy to send some pictures of mine if you
want.
