Posted by kollegewidgwock (kollegewidgwock@…>)
If the fuel tank on an 87 F30 is accidently overfilled, where does the
overflow go? I seen to remember a post earlier in this group that said
it went into the bildge and not overboard. Can anyone confirm this?
Don
You don’t want to overfill, but if it happens it will come out of the deck fill or the fuel tank air vent through hull.
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of kollegewidgwockSent: Monday, August 07, 2006 4:17 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Another fuel gauge question?
If the fuel tank on an 87 F30 is accidently overfilled, where does the overflow go? I seen to remember a post earlier in this group that said it went into the bildge and not overboard. Can anyone confirm this?Thanks,Don
Posted by Weeks MD, Andrew (aweeks@…>)
Its
vented overboard. Fill fuel tank till whistle changes tune.
AW
Sent: Monday, August 07, 2006 3:17
PM
To:
Don
Once again, thanks for the valuable information!
Don
kollegewidgwock
Don
I had this, and it was because one of the fuel filler hoses was not
clamped tight enough
— In freedomyachts2003@yahoogroups.com, “kollegewidgwock”
Don
