I also investigated this. There are some
mechanisms sold commercially for attachment to the rudder. I decided not to go
this route for the same reasons as Michel but in addition on a previous boat I
had a vane with trim tab on its own rudder and wasn’t satisfied with its
performance. Of course perhaps it was not sized properly. However, what I’ve
read always seems to favor servos.
I have used a small tiller pilot on my
voyager servo. It works great and uses very little power. I’ve used it
extensively in light air and when motoring. I’ve also used it in stronger
conditions when I was being lazy and it worked well.
Alan F-33 Hull #51 SEAPR
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of michel.capel
Sent: Monday, January 14, 2008
6:38 AM
Subject: [FreedomOwnersGroup] Re:
Anybody used Windvane self-steering?
I went into the issue of trim tabs when I was
selecting a vane for
my F33/35 catketch. I even considered sawing the aft most 4" off my
rudder to use that part as a trimtab.
In the end, I chose a servo pendulum system. Not because I doubt the
working of a trimtab. The reason was that the design of a trimtab is
so crucial, that you really cannot buy one off the shelf, although
they do exist. If you look at successful trimtab solutions, they are
mostly custom made by their knowledgeable owners. It would have
taken me a lot of trial and error to develop the best shaped
trimtab, and I did not want to ruin my rudder while trying and
making errors.
The design-fit between vane and boat of a servo pendulum is much
less critical as long as the vane can be mounted and is strong
enough the handled the necessary steering loads.
Good luck,
— In FreedomOwnersGroup@yahoogroups.com,
“phildowneyuk”
“Barry Stellrecht”
<yak@> wrote:
Phil,
I appreciate the list of models that would/have fit on the
transom
of
a F33. (or F35 on your side of the pond)
I’m not sure I follow your recommendations as you are giving
them,
though:
You say that a powerful windvane is needed to handle the big
barn
door
rudder and occasional heavy weather helm.
Then you say that you are planning to do a trim tab instead. As
I
understand it, a trim tab is less powerful than a servo pendulum
windvane. I do agree that it should be simpler, cheaper, and
easier
to home-brew successfully.
My main concerns on picking a windvane are how it controls the
boat
and how it fits on the boat. The fit problems would be the
transom
hung rudder and the odd way to route the control lines (through
tiller slot/cockpit drain slot in the transom) As for how
control
works, I am asking here to see what people have used and how
they
like
them.
Also, I have heard of tillerpilots being placed on the servo-
pendulum
models for compass steering as you suggest with the trim tab.
On Jan 9, 2008 4:30 PM, phildowneyuk <phildowneyuk@>
Hi I have also recently bought a f33 cat ketch, “Kusi”
and am facing this question myself.
I have seen monitor, aries and windpilot used and have
drawings
for
hydrovane bracket in the paperwork with my boat so any strong
one
would proably be ok but a freedom can quickly develop a load of
weather helm and there are high loads on the large rudder so
whatever
you choose it needs to be a heavy duty model
personaly , im going to attempt to avoid the clutter and
expense
of
an off the shelf vane and fit a trim tab to the rudder like
lin
larry pardey did on talesin, if nothing else you can put a
tillerpilot on the trim tab rudder and save battery power /
expensive
wheelpilot wear and tear.
trim tabs work on the principal that the main rudder can be
turned
using a trailing edge flap like on an aircraft wing
with a balanced trim tab (piviot aprox 25%from the front) only
a
tiny
input force by vane or tillerpilot is needed to turn the
rudder .
to attatch anything else to the tab the tiller or quadrant of
tab
needs to be fitted at the intersection of the axis of piviot
of
main rudder and the avis of pivot of the trim tab then the
autopilot
or vane can be attatched to this small tiller without the
rudders
movement messing it up THIS IS CRITICAL
the design criteria for the rest of the system i am less
clear on
but if in doubt read everything available , the pardeys
recomend a
book on their site and one could copy their setup roughly and
get
fiddling with it , since understanding the way these clver
devices
work and fine tuning the boat and vane setup has to be the key
to
getting the best out of it
hopefuly this way i shall save money , have a powerful
versatile
vane , and not end up with a ugly, vunerable bracket
cluttering my
stern … but im not past the design stage yet so im on the
lookout
for ideas
Phil Downey
no , i am not trying to save money here i could buy any boat and
any
setup i wanted
my problem with most vanes available is the brackets they are
mounted on in the freedom with its great big rudder i feel that a
gantry is too vunerable to accidental damage is a lot of weight in
completely the wrong place and is in the way of the stern ladder
is butt ugly on a otherwise pretty boat also my mooring is between
two piles 44 feet apart and i want some room left and not paying
for
another 4 feet of boat has its atractions (thet dont charge for
rudders but i think theyd measure me as 39 ft loa)
I work in the marine industry and i feel that you me and everyone
else are being if not lied to then at least substantialy mis lead
the reason that the most logical , effective and powerful system
for
steering a boat ie a trim tab isnt used , is that no one can make
money doing it
to make money you need a good product that with as little
modification as possible can be sold to most yottties.
take a look at all commercial gear they all obey this rule
all that is needed is an adjustable /custom bracket.
you cant make a trim tab gear that a city lawyer with money and no
time can have his yard put on the back of his yacht and expect to
work.
they must be custom built for each boat and adjusted til they work
well.hence no incentive to market such systems thus explaining
how
few are seen
but work they must. i have never used a vane myself but go to
paracay and look at lin and larry pardey.
they have been using them to cross oceans since before i was
born,
look at aircraft they have been using them for years, and big
ships
apparently have been known to use them to move their main rudders
as
primary control
the baisic physics of the situation says they must.
all wind vanes produce a small control force which must be
amplifred
a trim tab needs little force to turn it but by altrering the
effective cross section from a symetrical foil to that of a
aymetrical foil it must genenate lift and turn or stall
ok a crude paddle shoved sideways in the water tied to your tiller
will generate an enormous load of force and pull the rudder hard
over
when its stalled but a stalled rudder dosent steer the boat just
creates drag as any laser sailor knows
when haslar invented his gear and many others were developed
racing
yachts had counter sterns thus trim tabs were never a viable option
i shall make a neat trim tab carefuly thought out and simply but
definately not crudely made tab gear and see how it works if it
works
i will be very satisfied if not, work out why and if the tab was a
rubbish idea il buy something that does work and put up with the
big
bracket.
all the best phil d
