OK, I’ve tried to remove the ring, if that’s what it’s called-no way can I get that off. It’s stainless steel and nothing can fit into it to wedge it out and there isn’t something to grip to get it out. It doesn’t seem like a removeable ring. My winch is a 23-not 21 as was talked about before.
Thanks Bob, but how do I get to it.?
SWARD— On Thu, 7/10/08, rfurborough <r.furborough@…> wrote:
From: rfurborough <r.furborough@…>Subject: [FreedomOwnersGroup] Re: Barient WinchTo: FreedomOwnersGroup@yahoogroups.comDate: Thursday, July 10, 2008, 10:30 AM
Sward,I just uploaded the maintenance manual for the Barients #23 winch.Bob— In FreedomOwnersGroup@ yahoogroups. com, Sward <swardfullsail@ …> wrote:>> OK, I’ve tried to remove the ring, if that’s what it’s called-no way can I get that off. It’s stainless steel and nothing can fit into it to wedge it out and there isn’t something to grip to get it out. It doesn’t seem like a removeable ring. My winch is a 23-not 21 as was talked about before. > > Can I get some help on this? Thanks so much> > > > “Life is a Reach, then you Jibe”> > SWARD>
Bob, I found it-thanks
SWARD— On Thu, 7/10/08, Sward <swardfullsail@…> wrote:
From: Sward <swardfullsail@…>Subject: Re: [FreedomOwnersGroup] Re: Barient WinchTo: FreedomOwnersGroup@yahoogroups.comDate: Thursday, July 10, 2008, 10:46 AM
SWARD— On Thu, 7/10/08, rfurborough <r.furborough@ cox.net> wrote:
From: rfurborough <r.furborough@ cox.net>Subject: [FreedomOwnersGroup ] Re: Barient WinchTo: FreedomOwnersGroup@ yahoogroups. comDate: Thursday, July 10, 2008, 10:30 AM
Mr. furborough: What website did you go to to “upload” the barient
Manual? I need a 28+ manual. Bruce
— In FreedomOwnersGroup@yahoogroups.com, “rfurborough”
Sward,
I actually purloined my document from www.ericsonyachts.org, I have
checked there on your behalf and they have nothing listed for the 28+.
Barients was sold ultimately to Arco Winches in Australia and are now
known as Hutton-Arco, see www.huttonwinches.com. There is a little
information there about Barients winches, but not much.
I do have a general information sheet that Arco used to have listed
on their website. I’ll also post that to the files directory.
<r.furborough@> wrote:
Sward,
no
it
not
Bob
Thank you all so much for your help. The needle nose plyers did the trick. How exciting that at last something worked, now it’s just a matter of taking it apart and working on it. and of course not losing any parts-fat chance!!
SWARD— On Thu, 7/10/08, Bob Weeks <rweeks6508@…> wrote:
From: Bob Weeks <rweeks6508@…>Subject: RE: [FreedomOwnersGroup] Re: Barient WinchTo: FreedomOwnersGroup@yahoogroups.comDate: Thursday, July 10, 2008, 8:01 PM
Has anyone sen this site it has almost every barient winch model?
From: FreedomOwnersGroup@ yahoogroups. com [mailto: FreedomOwnersGroup@ yahoogroups. com ] On Behalf Of SwardSent: Thursday, July 10, 2008 10:46 AMTo: FreedomOwnersGroup@ yahoogroups. comSubject: Re: [FreedomOwnersGroup ] Re: Barient Winch
SWARD
