Hello all, I want to take my winches apart and grease and service them. Since Barient is no longer in business does anyone know where to get the pauls or spare parts to accomplish this task? One last comment on the outhaul line-is it possible to run a feeder line or new line attaching it to the old one and pulling it backwards to the end of the boom to replace. I understand about all the pulley’s/blocks inside, but wonder why I couldn’t do that without taking it all apart.“Life is a Reach, then you Jibe” SWARD
Hello again, No comments to my questions? Hope to get some help on these. Thanks Hello all, I want to take my winches apart and grease and service them. Since
Barient is no longer in business does anyone know where to get the pauls or spare parts to accomplish this task? One last comment on the outhaul line-is it possible to run a feeder line or new line attaching it to the old one and pulling it backwards to the end of the boom to replace. I understand about all the pulley’s/blocks inside, but wonder why I couldn’t do that without taking it all apart. “Life is a Reach, then you Jibe” SWARD “Life is a Reach, then you Jibe” SWARD
— In FreedomOwnersGroup@yahoogroups.com, Sward <swardfullsail@…> wrote:
Hello again,
reHello all,
is no
accomplish
this task?
try looking in the www.cs-bb.com archives for winch overhaul. They have a
lot of info.
If not when I get back home next week I’ll look up my files.
Harv F-25 Invicta II
new line
replace. I
that without
SWARD
SWARD
Posted by Al Lorman (ajl@…>)
Sward:
If
necessary, you can buy some spares for Barient winchers from this company is
Australia: http://www.huttonwinches.com/products/spares.
This clever fellow devised a way to make pawl springs for Barient
winches: http://www.wbryant.com/StellaBoat/fyi/winches/pawl/spring.htm.
I
stripped and cleaned the Barients on my former Freedom and did not need any
replacement parts. Most winch parts don’t wear out; they just get
clogged with old grease. To assure that you don’t lose any parts,
get a cardboard box and cut a hole in it the size of the winch base, place over
winch before disassembling and it will catch any pieces that want to drift
away.
Al
Lorman
Former
custodian of F30 Ab Initio
Current
custodian of Bristol 31.1 Seriatim
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Sward
Sent: Sunday, May 25, 2008 7:56 AM
Subject: [FreedomOwnersGroup] Barient Winches-Outhaul
Hello again,
No comments to my
Hello all,
Jibe”
SWARD
Jibe”
SWARD
Posted by Vicki Shumaker (finches@…>)
SWARD, did you try a Google search? I found a website in Australia
which sells parts for Barient and Barlow winches. Sounds like they
would be willing to work with you in trying to figure out exactly what
you’ll need. http://www.arco-winches.com
Vicki
sv Copacabana
Posted by Brad Kuether (bkuether@…>)
If you guys get stumped, the subject of Barient spare parts has been tossed around a lot at the C&C group.
“We” have the same issues trying to find parts…
Hopefully I won’t have that problem much longer.
-Brad, Mary, Monica, and Jarod Kuether84’ C&C 29 Mark IIMiddle River, MD
Sent: Sunday, May 25, 2008 7:22 PM
Subject: [FreedomOwnersGroup] Re:Barient Winches-Outhaul
SWARD, did you try a Google search? I found a website in Australia which sells parts for Barient and Barlow winches. Sounds like they would be willing to work with you in trying to figure out exactly what you’ll need. http://www.arco-winches.comVickisv Copacabana
