Posted by Nhat Khong (nhatkhong1@…>)
Hello,
I’m considering buying a Freedom 36’. But never sailed one and dont
know much about its configuration. Can someone help me answer these
questions?
The boat I looked at had a boom vang/kicker rod in place is a
topping lift configuration. Is this original, and has anyone had any
problem with a similar boom vang/kicker rod configuration?
Can the self tending jib be replaced with a roller furling self
tending jib?
-Nat
Nat:
I don’t believe that rigid boom vangs were standard. When they’ve been added, it is not uncommon to discontinue use of the topping lift.
I’ll have to defer to others on your second question.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Nhat KhongSent: Monday, September 18, 2006 3:03 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Boom Vang / Kicker Rod
Hello,I’m considering buying a Freedom 36’. But never sailed one and dontknow much about its configuration. Can someone help me answer thesequestions?1) The boat I looked at had a boom vang/kicker rod in place is atopping lift configuration. Is this original, and has anyone had anyproblem with a similar boom vang/kicker rod configuration?2) Can the self tending jib be replaced with a roller furling selftending jib?Thanks,-Nat
Al,
Thanks, for the info.
-Nat
<ajlorman@…> wrote:
Nat:
Al Lorman
F30 Ab Initio
Hello,
questions?
tending jib?
-Nat
