Broken anchorsprit - Forensics
Posted by Alan (akusinitz@…>)
At the risk of embarassing myself I thought I’d describe my mishap in
case the construction of the anchorsprit on F-33s and various other
models of Freedom is of interest.
My sad story:
Last year I got the anchor caught on a cable and put a fair amount
of stress the the sprit. I noticed what I believes at the time was
gelcoat crazing near the point of the sprit where the opening begins.
Didn;t give it much thought. But added a stainless steel support under
the sprit and bolted to the stem as well as a chain stopper on the
sprit. Figured this would be indestuctible.
I was considering cutting the end off the sprit in front of the roller
to make releasing and stowing my Delta 44 anchor easier requiring less
manual work and using the windlass. Never got to it …
Was sailing the anchor out at a crowded anchorage. Was alone and
looked away for a little too long (Yes I’ve looked away a little too
long before as well:-) while operating the windlass (freefall 900).
The anchor hit the sprit with a lot of force. I noticed widening of
the gelcoat cracks. Little did I know…
When I got back to check out the sprit is was cracked all the way
across on the bottom and the side to the top 1/4" of fiberglass. I
could easily flex upwards from there out to the roller by hand.
Downward it was well supported by the stainless support I added
otherwise I think it would have just broken clean off.
I cut off the sprit from the point of the opening forward. Here’s what
I found. The top is nicely laid up fiberglass about 1/4"think. This
was still in good shape and not cracked. The bottom was an extremely
thin layer of fiberglass maybe just one layer plus gelcoat and was
cracked through. The middle 1/5 inches was a a messy mishmash with
voids and cracked clean through. There was also some resin impregnated
foam all cracked clean through.
I believe the top layer flexed and the rest of the mashmash wasn’t
very strong and was brittle. So it looks thick but isn’t well laid up.
From the opening back all was well and looks better constructed.
I’ve never heard of anyone having this problem so maybe its just the
day they laid up my sprit.
Alan F-33 Hull #51 1982
Alan,
I’ve heard of and seen a lot of Freedoms with shortened, replaced or
reinforced catheads (anchorplatforms). In my owners manual it says
that the cathead is only suited to stow the anchor, not to take the
load of the boat pulling on the chain. On my previous Freedom (an
F33/35) the cathead was still good, but also had a lot of cracks.
This winter, my F44 was in tow over a 4 mile stretch of sea with
tide against wind. I had a small but very strong little tug that
dragged me along at 7 or 8 knots. I had the towrope led through the
hole in the cathead and over the bow roller towards the cleats. When
bumping up and down in the choppy sea, the cathead bent up and down
continuously. I was afraid it would snap off at the bow, but luckily
it held until we made port. I bought a stainless chainhook, a 24mm
line of 6 yards and a thick rubber snubber to make a line to take
the stress off the windlass and cathead when at anchor. On my
previous boat, I had a similar rope and hook.
— In freedomyachts2003@yahoogroups.com, “Alan” <akusinitz@…>
in
other
My sad story:
amount
begins.
under
roller
less
too
900).
of
what
This
extremely
impregnated
up.
Interesting. Didn’t realize others
had issues. I always use a snubber at anchor. But I do expect the roller/sprit
to take the force of raising and lowering the anchor even when there is some
force when breaking out the anchor. Just too hard to keep reattaching the
snubber as I raise the anchor.
Note that aft of the opening (on mine
about 1 or 2 inches aft) the resin mish mash turns to the usual balsa core. So
any cracks could result in wet or rotted balsa further weakening the sprit.
Alan
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of michel.capel
Sent: Sunday, August 13, 2006 6:08
AM
Alan,
in
other
My sad story:
amount
begins.
under
roller
less
too
900).
of
what
This
extremely
impregnated
up.
Alan F-33 Hull
#51 1982
My F33 has a custom platform of 2" SS tube bolted to the hull,with a bobstay. Rollers are fitted on a welded-up SS crosspiece,and the filler piece is teak. Very nice looking,and far stronger than the original design. I have ridden out 2 gales anchored up ,and no strain on the platform.
Sent: Saturday, August 12, 2006 9:37 PM
Subject: [freedomyachts2003] Broken anchorsprit - Forensics
At the risk of embarassing myself I thought I’d describe my mishap in case the construction of the anchorsprit on F-33s and various other models of Freedom is of interest.My sad story:Last year I got the anchor caught on a cable and put a fair amount of stress the the sprit. I noticed what I believes at the time was gelcoat crazing near the point of the sprit where the opening begins. Didn;t give it much thought. But added a stainless steel support under the sprit and bolted to the stem as well as a chain stopper on the sprit. Figured this would be indestuctible.I was considering cutting the end off the sprit in front of the roller to make releasing and stowing my Delta 44 anchor easier requiring less manual work and using the windlass. Never got to it …Was sailing the anchor out at a crowded anchorage. Was alone and looked away for a little too long (Yes I’ve looked away a little too long before as well:-) while operating the windlass (freefall 900). The anchor hit the sprit with a lot of force. I noticed widening of the gelcoat cracks. Little did I know…When I got back to check out the sprit is was cracked all the way across on the bottom and the side to the top 1/4" of fiberglass. I could easily flex upwards from there out to the roller by hand. Downward it was well supported by the stainless support I added otherwise I think it would have just broken clean off.I cut off the sprit from the point of the opening forward. Here’s what I found. The top is nicely laid up fiberglass about 1/4"think. This was still in good shape and not cracked. The bottom was an extremely thin layer of fiberglass maybe just one layer plus gelcoat and was cracked through. The middle 1/5 inches was a a messy mishmash with voids and cracked clean through. There was also some resin impregnated foam all cracked clean through. I believe the top layer flexed and the rest of the mashmash wasn’t very strong and was brittle. So it looks thick but isn’t well laid up.From the opening back all was well and looks better constructed.I’ve never heard of anyone having this problem so maybe its just the day they laid up my sprit.Alan F-33 Hull #51 1982
Sounds great. I installed a windlass a few
years back and then had a custom stainless angle iron support with an eye for a
snubber line made and installed in last winter. Didn’t want to undo all
this and start from scratch.
Today just installed an large stainless
Delta-23 roller bolting it through the sprit and the support under it.
Seems pretty solid. We’ll see.
Alan
is intended only for the personal and confidential use of the recipient(s) named
above and may be subject to attorney client privilege if so marked. If the
reader of this message is not the intended recipient or an agent responsible
for delivering it to the intended recipient, you are hereby notified that you
have received this document in error and that any review, dissemination,
distribution, or copying of this message is strictly prohibited. If you have
received this communication in error, please notify us immediately by e-mail,
and delete the original message.
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Jerome Weinraub
Sent: Sunday, August 13, 2006 9:33
AM
platform.
12, 2006 9:37 PM
Subject:
My sad story:
Alan F-33 Hull
#51 1982
The resin-impregnated foam sounds like the stuff I found under the
aft-most keelbolt of my (formerly) '82 Freedom 25. I’m told that the
J-24 also suffers from this strange bit of technology. Needless to
say when one tried to tighten this keelbolt, one never could do more
than crush that stuff. That bolt always leaked some until I removed
the resin-foam mixture, and partially filled the rear of the sump
with epoxy resin with chopped glass for extra strength. After that, I
was successful in tightening the rearmost keelbolt to a decent torque value.
Herm
My sad story:
On my F33/35, the core of the cathead was 1" plywood, I discovered
when I installed an electric windlass and had to drill through
cathead and deck. The plywood was wet, but not yet rotted away. I
put on the windlass in 2000 and it was a 1986 UK built boat. The
cracks in the cathead had obviously let in water.
— In freedomyachts2003@yahoogroups.com, “Alan Kusinitz”
<akusinitz@…> wrote:
Interesting. Didn’t realize others had issues. I always use a
snubber at
anchor. But I do expect the roller/sprit to take the force of
raising and
lowering the anchor even when there is some force when breaking
out the
anchor. Just too hard to keep reattaching the snubber as I raise
the anchor.
Note that aft of the opening (on mine about 1 or 2 inches aft)
the resin
mish mash turns to the usual balsa core. So any cracks could
result in wet
Alan
michel.capel
Sent: Sunday, August 13, 2006 6:08 AM
Subject: [freedomyachts2003] Re: Broken anchorsprit - Forensics
Alan,
or
When
down
luckily
— In freedomyachts2003@ <mailto:freedomyachts2003%
40yahoogroups.com>
yahoogroups.com, “Alan” <akusinitz@>
mishap
in
other
My sad story:
amount
was
begins.
under
roller
requiring
less
too
900).
of
way
I
Here’s
what
This
extremely
was
with
impregnated
wasn’t
laid
up.
With all this support under your sprit, I think you’ll be okay.
I’m thinking of mounting a solid steel strut under my sprit too; on
the F44 the platform protrudes 2.5’ in front of the stem. I also
want to be able to run a gennaker from the forward end of the sprit,
so now my mast is off, I can access the bow to get the bolts in.
Sounds great. I installed a windlass a few years back and then had
a custom
stainless angle iron support with an eye for a snubber line made
installed in last winter. Didn’t want to undo all this and start
from
scratch.
Today just installed an large stainless Delta-23 roller bolting it
through
Alan
The information contained in this e-mail and any attachments is
intended
named above
the reader
responsible for
that you
dissemination,
If you have
by
e-mail, and delete the original message.
Weinraub
Sent: Sunday, August 13, 2006 9:33 AM
Subject: Re: [freedomyachts2003] Broken anchorsprit - Forensics
a
filler
original design.
platform.
To: freedomyachts2003@ <mailto:freedomyachts2003@yahoogroups.com>
yahoogroups.com
in
other
My sad story:
begins.
under
roller
less
too
900).
of
what
This
extremely
impregnated
up.
