Posted by Carl Hewitt (x365tech@…>)
I purchased a 91 freedom 38 last year and have been doing a refit on it.
The first major project I undertook was to purchase a new main and jib. All is great with the main, the jib however has caused me some issues. The primary one is in order to hoist it or lower it we had to make the forstay very, very loose. Even as such it does not go up or down very well. it is like the camber spar is longer than the sail is wide, so, there is a real angle in the forstay that is need (it has to “make a corner”)
The company that made the sails said this is how it is supposed to be. Has anyone else had this experience?
Part of the problem may be that the fitting at the front of the camberspar is warn and does not turn. These parts need to be replaced. I cannot find who the manufacturer is for these parts, any help with contact information would be much appreciated.
Carl
Do you ha
__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
I believe that parts for the Camberspar are available from Bierig Sailmakers, 11092 Freeport Lane, North East, PA 16428, 814-459-8001. Dave Bierig invented the Camberspar.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Carl HewittSent: Saturday, June 18, 2005 10:40 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] CamberSpar Parts and Jib Issues
Carl
Do you ha
__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed on the taxpayer. If any such tax advice is made to any person or party other than to our client to whom the advice is directed, then the advice expressed above is being delivered to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of the transaction or matter discussed or referenced. Each taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisor. This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Hi Carl -
Try calling Bierig Sail makers at 814-459-8001. They make the camber spars and have parts. Doyle sails will also be helpful - 781-639-1490 last I knew.
The small wheel at the forward end of the camber spar does have to turn freely, so do not over-tighten the nut on the retaining bolt.
There will always be a “bend” in the forestay - that is the nature of the beast. No way to “tighten” the head stay to the point where there is no bend, since there are no back stays or shrouds to counteract the force.
Tighten it so it is not “floppy”, but not so tight that you distort the mast when viewed from either side.
I hope that helps.
John Ernst
F45 Destiny
Hertford, NC
