Hello, Maybe Michael or someone can give me a source for my companionway step surface. Right now its has a surface with a grip. Does not go to the edges of the wood steps. I would have to tear it up…maybe with an iron heating it? It looks ragged, and needs replacement. Thank you for any ideas…Lola
Lola,
I have the same stuff, looks like sandpaper and starts to wear at the
edge. I only know of the 3/4" or 1" wide strips of non-skid, not wider
sheets that we have. A hot iron could work, or tear away and use a
chemical stripper for the remains and the glue. A hot iron would
surely damage the varnish.
— In FreedomOwnersGroup@yahoogroups.com, Lola Jackson <lolaltd@…>
Heat gun will help loose up and
unfortunate West Marine (everything cost five times more then need be but they
are the only ones that sell small quantities) has plastic razor blades that do
wonders for help get off sticky stuff. Heat gun you can control the heat
slowly apply heat in area then working you way across.
Bob
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Lola Jackson
Sent: Saturday, May 24, 2008 3:57
PM
To: freedom group
Subject: [FreedomOwnersGroup] Companion Way Steps
Surface.
Check on the Treadmaster non-skid in Defender catalog, pg. 128, or
West marine, pg. 813 for wider strips of stick-on nonskid pads.
Herm
At 09:00 AM 5/26/2008, you wrote:
Lola,
surely damage the varnish.Michel
— In
wrote:Hello, Maybe Michael or someone can give me a source for my
Hair Dryer is a fairly capable “heat gun”. Herm
At 10:05 AM 5/26/2008, you wrote:
Heat gun will help loose up and unfortunate West Marine (everything
cost five times more then need be but they are the only ones that
sell small quantities) has plastic razor blades that do wonders for
help get off sticky stuff. Heat gun you can control the heat slowly
apply heat in area then working you way across.Bob
Sent: Saturday, May 24, 2008 3:57 PM
To: freedom group
Subject: [FreedomOwnersGroup] Companion Way Steps Surface.Hello, Maybe Michael or someone can give me a source for my
Posted by Al Lorman (ajl@…>)
I bought an attractive gray 3" self stick nonskid tape on the Internet.
Al
Law Office of
Alvin J. Lorman
1629 K Street, NW, Suite 300
Washington, DC 20006
Tel/Fax: 202.263.1100
Cell: 202.236.2359
Sent from my BlackBerry Wireless
-----Original Message-----
Date: Mon, 26 May 2008 10:36:43
To:FreedomOwnersGroup@yahoogroups.com
Subject: Re: [FreedomOwnersGroup] Re: Companion Way Steps Surface.
Herm
Lola,
— In
mailto:FreedomOwnersGroup%40yahoogroups.com yahoogroups.com,
Hey thanks all…I was wondering also what other materials, that could be non slip surface…But will go with Herm’s suggestion so far. You all are such an asset to me…Thought I would tell you I’m converting thin shower curtains in my open sides in cock pit for privacy in port, and tie em back or remove when sail…will send photos when i get them done…LolaHerman and Gail Schiller <hschiller2@…> wrote: Check on the Treadmaster non-skid in Defender catalog, pg. 128, or West marine, pg. 813 for wider strips of stick-on nonskid pads. Herm At 09:00 AM 5/26/2008, you wrote: >Lola, > >I have the same stuff, looks like sandpaper and starts to wear at the >edge. I only know of the 3/4" or 1" wide strips of non-skid, not wider >sheets that we have. A hot iron could work, or tear away and use a >chemical stripper for the remains and the glue. A hot iron would >surely damage the varnish. > >Michel > >— In >mailto:FreedomOwnersGroup%40yahoogroups.comFreedomOwnersGroup@yahoogroups.com, >Lola Jackson <lolaltd@…> >wrote: > > > >
Hello, Maybe Michael or someone can give me a source for my >companionway step surface. Right now its has a surface with a grip. >Does not go to the edges of the wood steps. I would have to tear it >up…maybe with an iron heating it? It looks ragged, and needs >replacement. Thank you for any ideas…Lola > > > >
I use ultimate sole on my cabin sole and
companionway ladder. Its some like a varnish but specifically designed for this
purpose. It tested very well for traction when wet. It looks glossy but I’ve
felt very secure on it.
Alan
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Lola Jackson
Sent: Monday, May 26, 2008 3:22 PM
Re: Companion Way
Steps Surface.
Herm
Lola,
wider
— In
Where do you buy it? W Marine? LolaAlan Kusinitz <akusinitz@…> wrote: I use ultimate sole on my cabin sole and companionway ladder. Its some like a varnish but specifically designed for this purpose. It tested very well for traction when wet. It looks glossy but I’ve felt very secure on it. Alan From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Lola Jackson Sent:
Monday, May 26, 2008 3:22 PM To: FreedomOwnersGroup@yahoogroups.com Subject: Re: [FreedomOwnersGroup] Re: Companion Way Steps Surface. Hey thanks all…I was wondering also what other materials, that could be non slip surface…But will go with Herm’s suggestion so far. You all are such an asset to me…Thought I would tell you I’m converting thin shower curtains in my open sides in cock pit for privacy in port, and tie em back
or remove when sail…will send photos when i get them done…Lola Herman and Gail Schiller <hschiller2@suddenlink.net> wrote: Check on the Treadmaster non-skid in Defender catalog, pg. 128, or West marine, pg. 813 for wider strips of stick-on nonskid pads. Herm At 09:00 AM 5/26/2008, you wrote: >Lola, > >I have the same stuff, looks like sandpaper and starts to wear at the >edge. I only know of the 3/4" or 1" wide strips of non-skid, not wider >sheets that we have. A hot iron could work, or tear away and use a >chemical stripper for the remains and the glue. A hot iron would >surely damage the
varnish. > >Michel > >— In >mailto:FreedomOwnersGroup%40yahoogroups.comFreedomOwnersGroup@yahoogroups.com, >Lola Jackson <lolaltd@…> >wrote: > > > > Hello, Maybe Michael or someone can give me a source for my >companionway step surface. Right now its has a surface with a grip. >Does not go to the edges of the wood steps. I would have to tear it >up…maybe with an iron heating it? It looks ragged, and needs >replacement. Thank you for any ideas…Lola > > > >
Posted by ron barr (rwhb@…>)
Try Treadmaster – it is available both in “step”
sections or in a sheet. I bought a sheet years ago and it is the cheapest way
to go in the long run since I have used it on two boats already and still have
some left over.
Ron
Hoyt F32
Newport RI
Thanks Ron…Lolaron barr <rwhb@…> wrote: Try Treadmaster – it is available both in “step” sections or in a sheet. I bought a sheet years ago and it is the cheapest way to go in the long run since I have used it on two boats already and still have some left over. Ron Hoyt F32 Newport
RI
Go to Home Depot and buy some black rubber like stair tread with raised
ridges. Cut to fit and use contact cement. Dirt cheap and I guarantee
that it is absolutely slip proof. John Jones 33 #55
when i get them done…Lola/Herman and Gail Schiller <hschiller2@…>/ wrote:
Check on the Treadmaster non-skid in Defender catalog, pg. 128, or West marine, pg. 813 for wider strips of stick-on nonskid pads. Herm At 09:00 AM 5/26/2008, you wrote: >Lola, > >I have the same stuff, looks like sandpaper and starts to wear at the >edge. I only know of the 3/4" or 1" wide strips of non-skid, not wider >sheets that we have. A hot iron could work, or tear away and use a >chemical stripper for the remains and the glue. A hot iron would >surely damage the varnish. > >Michel > >--- In
mailto:FreedomOwnersGroup%40yahoogroups.com,
http://www.ultimatesole.com/
If its just for your ladder its pricey
since you have to buy a whole quart. Of course the rubber treads or
treadmaster are really good for traction so it depends on your preferences.
Alan
Sent: Monday, May 26, 2008 3:42 PM
Re: Companion Way
Steps Surface.
Where do
Alan Kusinitz
Alan
Re: Companion Way
Steps Surface.
Herm
Lola,
wider
— In
Thanks Alan…Its for the Companionway steps. I went to the Ultimatesole, and that looks good too. Do you think the wood shows through? I have some good advice from you all. Thanks for all the options…LolaAlan Kusinitz <akusinitz@…> wrote: http://www.ultimatesole.com/ If its just for your ladder its pricey since you have to buy a whole quart. Of course the rubber treads or treadmaster are really good for traction so it depends on your preferences. Alan From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Lola Jackson Sent: Monday, May 26, 2008 3:42 PM To: FreedomOwnersGroup@yahoogroups.com Subject: RE: [FreedomOwnersGroup] Re: Companion Way Steps Surface. Where do you buy it? W Marine? Lola Alan Kusinitz <akusinitz@yahoo.com> wrote: I use ultimate sole on my cabin sole and companionway ladder. Its some like a varnish but specifically designed for this purpose. It tested very well for traction when wet. It looks glossy but I’ve felt very secure on it. Alan From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Lola Jackson Sent: Monday, May 26, 2008 3:22 PM To:
tie em back or remove when sail…will send photos when i get them done…Lola Herman and Gail Schiller <hschiller2@suddenlink.net> wrote: Check on the Treadmaster non-skid in Defender catalog, pg. 128, or West marine, pg. 813 for wider strips of stick-on nonskid pads. Herm At 09:00 AM 5/26/2008, you wrote: >Lola, > >I have the same stuff, looks like sandpaper and starts to wear at the >edge. I only know of the 3/4" or 1" wide strips of non-skid, not wider >sheets that we have. A hot iron could work, or tear away and use a >chemical stripper for the remains and the glue. A hot iron
would >surely damage the varnish. > >Michel > >— In >mailto:FreedomOwnersGroup%40yahoogroups.comFreedomOwnersGroup@yahoogroups.com, >Lola Jackson <lolaltd@…> >wrote: > > > > Hello, Maybe Michael or someone can give me a source for my >companionway step surface. Right now its has a surface with a grip. >Does not go to the edges of the wood steps. I would have to tear it >up…maybe with an iron heating it? It looks ragged, and needs >replacement. Thank you for any ideas…Lola > > > >
Yes it’s a clear gloss coating. Its
surprising its got good traction. When you look at it you’ld think it
would be slippery. But this is what it was designed for supposedly. It looks
great on my teak and holly sole. Just light sand and brush on with the foam
brushes they recommend. (Some foam brushes get dissolved from whatever is in
it).
Alan
Sent: Monday, May 26, 2008 7:32 PM
Re: Companion Way
Steps Surface.
Alan Kusinitz
Alan
Re: Companion Way
Steps Surface.
Alan Kusinitz
Alan
Re: Companion
Way Steps Surface.
Herm
Lola,
wider
— In
Lola:
Chandleries (including Defernder and West MArine) have a white sticjy-backed
tape with a rough surface. Clean off the steps, measure the langth of tape you
need , cut it (I round off the ends so the corners don’t stick uo, plus it looks
better) peel off the back and apply it to the steps or the companionway ladder.
I’ve been using it for years and replace it every 2 or 3 yuears, as it gets gray
and dinngy. I also varnish the ladder before aapplying . I use thrtee stips on
the top of the ladder and two stips on the other steps. When the ladder is
varnished, it makes a noce contrast with the white stripes. And it is a very
effective non-skid.–
Steve Gaber
Sanderling, 1967 C-31 #77
Oldsmar, FL
---- Lola Jackson <lolaltd@…> wrote:
Thanks Ron…Lola
since I have used it on two boats already and still have some left over.Ron
Hoyt F32
Newport RI
Try lacquwer thinner or acetone. But don’t use those on any varnished or painted
surface unless you intend to re-do them.
Steve Gaber
Oldsmar, FL
---- Bob Weeks <rweeks6508@…> wrote:
Heat gun will help loose up and unfortunate West Marine (everything cost
five times more then need be but they are the only ones that sell small
quantities) has plastic razor blades that do wonders for help get off sticky
stuff. Heat gun you can control the heat slowly apply heat in area then
To: freedom group
Subject: [FreedomOwnersGroup] Companion Way Steps Surface.Hello, Maybe Michael or someone can give me a source for my companionway
ideas…Lola
