— In freedomyachts2003@yahoogroups.com, “macks011” <macks04@o…>
for
When you install the seal, you are pressing the shaft in blind. It
is so tight , that there is literally no exposed shaft. Get a
center
punch and dimple the… INTERIOR COUPLING END… on either side
of the key way. This
will prevent the key from sliding back as you press in the shaft.
