crazing on deck gelcoat F32
Posted by jackcarles (johncarles@…>)
I have been shopping for a F32 and all that i have seen have serious
deckside gelcoat crazing. Has anyone investigated this issue and found
a resolution?
TPI put the gelcoat on a bit too thick.
Common on Freedoms.
Only cosmetic.
— In freedomyachts2003@yahoogroups.com, “jackcarles” <johncarles@…>
a resolution?
Not uncommon, as Dave says. My deck was sprayfilled with two coats of
a special thick undercoat from awlgrip, sanded in between coats and
then sprayed with 2 coats of outer paint.
found
a resolution?
Posted by John Carles (johncarles@…>)
thanks. JackDave_Benjamin <dave_benjamin@…> wrote: TPI put the gelcoat on a bit too thick. Common on Freedoms. Only cosmetic. — In freedomyachts2003@yahoogroups.com, “jackcarles” <johncarles@…> wrote: > > I have been shopping for a F32 and all that i have seen have serious > deckside gelcoat crazing. Has anyone investigated this issue and found > a resolution? > >
Thanks >
ThanksJack"michel.capel" <michel.capel@…> wrote: Not uncommon, as Dave says. My deck was sprayfilled with two coats of a special thick undercoat from awlgrip, sanded in between coats and then sprayed with 2 coats of outer paint. — In freedomyachts2003@yahoogroups.com, “jackcarles” <johncarles@…> wrote: > > I have been shopping for a F32 and all that i have seen have serious > deckside gelcoat
crazing. Has anyone investigated this issue and found > a resolution? > > Thanks >
