deck painting
Posted by seychellois_lib (seychellois_lib@…>)
After years of washdowns and general wear and tear I am beginning to
see the gray paint on deck starting to wear through. Has anyone had
the paint redone profesionally? If so what is the price range? This is
one job I am very reluctant to try as a DYI effort.
Mike
F30#3
Jacqueline
I’m using Durabak 18 to redo my decks. I read an article in Good Old Boat that detailed this material and the approach. I’ve done portions to try it and it seems great. It has rubber based nonskid so although it looks rough I have found it quite comfortable to knell and sit on and excellent traction wet or dry. I can’t comment on longevity but the person wrote the article 3 years after doing the job and said it was still in like new condition. Apparently this stuff is used on commerical fishing boats and ferries as well.
Alan F-33 Hull#51 SEAPR
Sent: Sunday, August 21, 2005 10:31 AM
Subject: [freedomyachts2003] deck painting
After years of washdowns and general wear and tear I am beginning tosee the gray paint on deck starting to wear through. Has anyone hadthe paint redone profesionally? If so what is the price range? This isone job I am very reluctant to try as a DYI effort.MikeF30#3Jacqueline
Alan:
Are you applying the Durabeck over the molded in nonskid?
Al Lorman
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Alan KusinitzSent: Sunday, August 21, 2005 11:04 AMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] deck painting
After years of washdowns and general wear and tear I am beginning tosee the gray paint on deck starting to wear through. Has anyone hadthe paint redone profesionally? If so what is the price range? This isone job I am very reluctant to try as a DYI effort.MikeF30#3JacquelineIRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Yes. I sand with 60-80 grit and a palm sander to roughen the surface but don;t bother to sand the original nonskid off. I tried a small area first and the durabak covered beautifully.since it is thick and rubbery.
Alan
Sent: Sunday, August 21, 2005 12:40 PM
Subject: RE: [freedomyachts2003] deck painting
Alan:
Al Lorman
