Diesel engine operation
In the last week or so someone stated that they were relying on their temperature gauge to indicate that their engine was operating efficiently and at high enough RPM to prevent undue wear.
From what I have been told this is not a good idea. As with your car’s engine, the thermostat restricts the flow of cooling water to bring coolant temperature up to normal as quickly as possible. This can happen even at idle RPMs However, the temperature of the engine’s many parts will still be below optimum temperature even when the temperature gauge says it is hot. This low temperature condition will continue until a substantial load is placed on the engine.
Moral of the story is DON’T RUN UNDER LIGHT LOAD VERY OFTEN OR FOR VERY LONG. A few minutes of idle is recommended on start up and before shut down.
If any of this is incorrect please let me know.
Bill
Sailing F-36 #46 (1986) Hard Earned out of New Bedford Yacht Club
Padanaram, MA
Bill,
This is what they told me also about diesel engines.
Mike
before shut down.
Bill
Padanaram, MA
Posted by Don Young (donzenet@…>)
My understanding, as well. However, pulling into a “truck stop” fuel
station always reveals several big rig trucks doing just that - engine at
idle for hours at a time.
Don
-----Original Message-----
Sent: Friday, March 04, 2005 7:41 AM
Subject: [freedomyachts2003] Re: Diesel engine operation
Bill,
Mike
before shut down.
Bill
Padanaram, MA
Yahoo! Groups Links
Bill is
correct.
The truckers
that let there engines idle will pay the price of fuel dilution of the lube oil
and eventually polishing of the cylinders which leads to burning oil.
Most of them are doing that for heat in the sleeper. Some have APU’s to do that rather then to put ware and tare on the main
engine.
Engine warm up
is recommended but not necessarily to operating temp, get underway and keep the
load light till maybe 20 minutes out. Long periods of idle, like to
charge batteries of refrigeration is the worst thing you can do to a diesel.
Though you need not necessarily operate at 95% of rated continuous to keep the
engine loaded, running at 80% of max RPM is very reasonable.
It the engine is overheating or underheating, you have some troubleshooting and
work to do.
Brian
Guptil
sailordude@…
[mailto:donzenet@…]
Sent: Sunday, March 06, 2005 7:17 AM
Subject: RE: [freedomyachts2003]
a “truck stop” fuel
Don
operation
Bill,
engines.
Mike
undue wear.
idea. As with your
cooling water to
as possible. This
temperature of the
on the engine.
before shut down.
know.
Bill
Padanaram, MA
Yahoo! Groups Links
Whomever ran my engine for the last eleven years must
have followed those procedures. Purrs like a kitten,
leaks nothing.
You can definitely tell. Cheers, ‘captain’ jacqui
mac, Sparrow
– Brian Guptil <sailordude@…> wrote:
Bill is correct.
The truckers that let there engines idle will pay
of the lube oil and eventually polishing of the
burning oil. Most of them are doing that for heat
tare on the main engine.
Engine warm up is recommended but not necessarily to
operating temp, get
underway and keep the load light till maybe 20
idle, like to charge batteries of refrigeration is
do to a diesel. Though you need not necessarily
continuous to keep the engine loaded, running at 80%
of max RPM is very
reasonable. It the engine is overheating or
troubleshooting and work to do.
Brian Guptil
mailto:sailordude@...
sailordude@…
Subject: RE: [freedomyachts2003] Re: Diesel engine
operation
“truck stop” fuel
Don
operation
Bill,
Mike
A. Cormack”
were relying on
wear.
idea. As with your
cooling water to
possible. This
temperature of the
the engine.
VERY OFTEN OR FOR
start up and
before shut down.
Bill
Bedford Yacht Club
Padanaram, MA
Yahoo! Groups Links
Yahoo! Groups Sponsor
ADVERTISEMENT
<http://us.ard.yahoo.com/SIG=1298m6280/M=298184.6018725.7038619.3001176/D=gr
oups/S=1705065792:HM/EXP=1110208639/A=2593423/R=0/SIG=11el9gslf/*http:/www.n
etflix.com/Default?mqso=60190075> click here
<http://us.adserver.yahoo.com/l?M=298184.6018725.7038619.3001176/D=groups/S=
:HM/A=2593423/rand=840813790>
Yahoo! Groups Links
  •     To visit your group on the web, go to:
  •     To unsubscribe from this group, send an
email to:
<mailto:freedomyachts2003-unsubscribe@yahoogroups.com?subject=Unsubscribe>
  •     Your use of Yahoo! Groups is subject to
the Yahoo! Terms of
http://docs.yahoo.com/info/terms/ Service.
Celebrate Yahoo!'s 10th Birthday!
Yahoo! Netrospective: 100 Moments of the Web
http://birthday.yahoo.com/netrospective/
