Electrical Fun - Bilge
Posted by jsforgey (jsforgey@…>)
My bilge pump (Rule 1000) tripped the circuit on the panel after
having run my batteries down.
I changed it out in a snap and installed the new one it still trips.
Hmmm.
I checked the float switch but dont see a problem…electricity flows
through it easily. What to do?
Suggestions? Is it time to buy a multimeter?
Bilge is pretty dry…but it would be nice to fix this quick.
Scott
F-32 Girlfirend
Posted by Capt. Herman (sailtampa@…>)
greetings…
sounds like you have a short in the wires…
track the wires from the bilge to the switch and to the batteries…making sure they aren’t worn and shorting against each other…
Capt. Herman
Sent: Saturday, October 04, 2008 4:55 PM
Subject: [FreedomOwnersGroup] Electrical Fun - Bilge
My bilge pump (Rule 1000) tripped the circuit on the panel afterhaving run my batteries down.I changed it out in a snap and installed the new one it still trips. Hmmm.I checked the float switch but dont see a problem…electricity flowsthrough it easily. What to do?Suggestions? Is it time to buy a multimeter?Bilge is pretty dry…but it would be nice to fix this quick.ScottF-32 Girlfirend
Roger that. Sent from my Verizon Wireless BlackBerryFrom: “Capt. Herman” <sailtampa@…>Date: Sat, 4 Oct 2008 17:24:28 -0400To: <FreedomOwnersGroup@yahoogroups.com>Subject: Re: [FreedomOwnersGroup] Electrical Fun - Bilge greetings…sounds like you have a short in the wires…track the wires from the bilge to the switch and to the batteries…making sure they aren’t worn and shorting against each other…Capt. Herman ----- Original Message ----- From: jsforgey To: FreedomOwnersGroup@yahoogroups.com Sent: Saturday, October 04, 2008 4:55 PM Subject: [FreedomOwnersGroup] Electrical Fun - Bilge My bilge pump (Rule 1000) tripped the circuit on the panel afterhaving run my batteries down.I changed it out in a snap and installed the new one it still trips. Hmmm.I checked the float switch but dont see a problem…electricity flowsthrough it easily. What to do?Suggestions? Is it time to buy a multimeter?Bilge is pretty dry…but it would be nice to fix this quick.ScottF-32 Girlfirend
Scott, is the discharge hose blocked?
SWARD— On Sat, 10/4/08, jsforgey <jsforgey@…> wrote:
From: jsforgey <jsforgey@…>Subject: [FreedomOwnersGroup] Electrical Fun - BilgeTo: FreedomOwnersGroup@yahoogroups.comDate: Saturday, October 4, 2008, 4:55 PM
My bilge pump (Rule 1000) tripped the circuit on the panel afterhaving run my batteries down.I changed it out in a snap and installed the new one it still trips. Hmmm.I checked the float switch but dont see a problem…electrici ty flowsthrough it easily. What to do?Suggestions? Is it time to buy a multimeter?Bilge is pretty dry…but it would be nice to fix this quick.ScottF-32 Girlfirend
Posted by Scott Forgey (jsforgey@…>)
OK.
This is another one of those “I should know but I really don’t”
kind of questions. How do you track down a short?
I have some ideas and am able to do some basic work, but it is
time to get scientific from anyone who knows what they are doing as I stumble
in the dark (without my bilge pump).
Good thing she takes on very little water. Nearly none.
Thanks.
Scott Forgey
21362 Summertrace Circle
Boca Raton, FL 33428
561.445.5179
skype: sforgey1
“Nothing is ever wrong in the universe, there is only
what’s missing!”
W. Erhard
Behalf Of Capt. Herman
Sent: Saturday, October 04, 2008 5:24 PM
greetings…
sounds
track
Capt.
Herman
04, 2008 4:55 PM
on the panel after
Hmmm.
Scott
F-32 Girlfirend
Checked by AVG.
Version: 7.5.524 / Virus Database: 270.7.5/1706 - Release Date: 10/3/2008 6:17
PM
Checked by AVG.
Version: 7.5.524 / Virus Database: 270.7.6/1709 - Release Date: 10/5/2008 9:20 AM
Laborious though it may seem, you have to physically trace the wire
from the fuse/circuit breaker to the device, and look for ugly
physical condition(s). That is, a break in the insulation, probably
at a spot where the wire has rubbed on, or bounced against, another
electrical device. OR, just route a new wire, and disconnect, label
and tape up the old wire. Herm
At 12:00 PM 10/5/2008, you wrote:
OK.
This is another one of those “I should know but I really don’t” kind
I have some ideas and am able to do some basic work, but it is time
stumble in the dark (without my bilge pump).
Thanks.
Scott Forgey
561.445.5179
skype: sforgey1
“Nothing is ever wrong in the universe, there is only what’s missing!”
                 W. Erhard
[mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of Capt. Herman
greetings…
Capt. Herman
To:
<mailto:FreedomOwnersGroup@yahoogroups.com>FreedomOwnersGroup@yahoogroups.com
Hmmm.
Scott
F-32 Girlfirend
Checked by AVG.
10/3/2008 6:17 PM
Checked by AVG.
10/5/2008 9:20 AM
Scott,
I had a comparable problem. My bilge pump tripped the fuse and the
wires got hot. I replaced the wiring for heavier gauge. The oled
wiring was wet and corroded. The problem is over now. I also replaced
the float switch; the old one still worked but I could not establish
if it had more than normal resistance. If I were in your shoes, I
would try the pump and switch and other components with a temporary
new wire and see if things still went wrong. It’s also possible that
the resistance in the pump itself is too high. Is the pump motor still
okay? Worn or loose carbon brushes also cause problems like you describe.
Good luck,
— In FreedomOwnersGroup@yahoogroups.com, “Scott Forgey”
<jsforgey@…> wrote:
OK.
This is another one of those “I should know but I really don’t” kind of
to get
scientific from anyone who knows what they are doing as I stumble in the
Thanks.
Scott Forgey
561.445.5179
skype: sforgey1
                 W. Erhard
greetings…
batteries…making
Capt. Herman
To: HYPERLINK
"mailto:FreedomOwnersGroup@yahoogroups.com"FreedomOwnersGroup@…
m
Hmmm.
Scott
F-32 Girlfirend
Checked by AVG.
10/3/2008
6:17 PM
Checked by AVG.
10/5/2008
9:20 AM
Thank you for your suggestion.
The pump motor was worn. I replace it. I replaced
the wiring to and fro as well . The float switch seems fine.
It is now working, but I am always unsatisfied when I am not
sure the source of the electrical failure.
She is a dry boat, so the bilge pump doesn’t go off that
often…but still…
Scott
Girlfriend F-32 (Hoyt)
Scott Forgey
561.445.5179
skype: sforgey1
what’s missing!”
W. Erhard
Behalf Of michel.capel
Sent: Sunday, October 05, 2008 3:14 PM
Subject: [FreedomOwnersGroup] Re: Electrical Fun - Bilge
Scott,
Good luck,
“Scott Forgey”
<jsforgey@…> wrote:
OK.
kind of
to get
Thanks.
Scott Forgey
561.445.5179
skype: sforgey1
missing!”
W. Erhard
greetings…
batteries…making
Capt. Herman
To: HYPERLINK
m
Hmmm.
Scott
F-32 Girlfirend
Checked by AVG.
10/3/2008
6:17 PM
Checked by AVG.
10/5/2008
9:20 AM
Checked by AVG.
AM
Checked by AVG.
Version: 7.5.549 / Virus Database: 270.8.5/1758 - Release Date: 10/31/2008 8:22 AM
