Electrical Grounding Points
Posted by Michael Gillin (michael_w_gillin@…>)
I have another question if you don’t mind. I want to hang a zinc anode
off the stern while at the dock.
We have a serious electrolysis issue here.
I have a bolt with a wing nut attached on the stbd coaming on the
stern. Using a meter it seems to be a ground source. Is is possible
the factory provided this ground point for use in hanging zincs ?
If not what do you suggest as a known ground source ?
Thank you
