Electrolysis onF-28
Posted by brucestrt (brucestrt@…>)
Just purchased a Mull 28 in Los Angeles in generally excellent
condition. Only two problems so far. First, when hauled for survey
there was what appeared to be corrosion on the keel near the bottom
and zincs were in need of replacement. Today the boats diver informed
me that the boat has been eating zincs at an unusual pace for at least
a couple years or more and the p/o simply replaced them, every one or
two months. the boat had bad gel batteries which have been replaced
with wet cells but doubt this was the problem. The boat normally does
not have shore power connected. Second problem was some dry rot under
the main bulkhead due to fresh water in the bottom of the mast and
what appeared to be a plugged up drain from mast to bilge. Foreward
two feet of teak and holly sole will have to be replaced and some
epoxy used under the head area. Cannot see the mast base. Is either
of these problems likely to be affecting the carbon mast? Any
comments or suggestions weill be appreciated. Excuse the long first
message.
Bruce
Bruce:
Welcome to the Freedom family.
I’m no expert in marine electric, but I doubt that your keel, which is lead, is experiencing corrosion. Eating zincs is a different problem. You cold a multimeter to see if any of the electrical circuits are 'leaking" when in the off position. Also, make sure that everything that is supposed to be grounded is grounded. If the boat is docked in a particularly electrically “hot” area, you might try one of the zinc fishes that clip onto your grounding system and then go overboard.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of brucestrtSent: Tuesday, February 07, 2006 8:00 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Electrolysis onF-28Just purchased a Mull 28 in Los Angeles in generally excellentcondition. Only two problems so far. First, when hauled for surveythere was what appeared to be corrosion on the keel near the bottomand zincs were in need of replacement. Today the boats diver informedme that the boat has been eating zincs at an unusual pace for at leasta couple years or more and the p/o simply replaced them, every one ortwo months. the boat had bad gel batteries which have been replacedwith wet cells but doubt this was the problem. The boat normally doesnot have shore power connected. Second problem was some dry rot underthe main bulkhead due to fresh water in the bottom of the mast andwhat appeared to be a plugged up drain from mast to bilge. Forewardtwo feet of teak and holly sole will have to be replaced and someepoxy used under the head area. Cannot see the mast base. Is eitherof these problems likely to be affecting the carbon mast? Anycomments or suggestions weill be appreciated. Excuse the long firstmessage.Bruce
Lead is not that far from zinc on the galvanic ladder, so if zincs
are eaten quickly, I wouldn’t be surprised that lead is also nibbled
at. Strange though that the boat is usually not connected to
shorepower and still has electrolysis going on. Is the boat berthed
close to a steel quayside? If so, the quayside could be protected
against corrosion with an active system. If this is the case, I
would move the boat away, because no matter what you do, electric
currents will remain running around the boat.
Perhaps connecting the shore power - provided there’s a good
galvanic isolation in the system - could improve the situation.
good luck,
<ajlorman@…> wrote:
Bruce:
which is
problem.
everything
docked in a
Al Lorman
F30 Ab Initio
survey
informed
least
or
replaced
does
under
Foreward
either
first
message.
Bruce
SPONSORED LINKS
Sailing schools
<http://groups.yahoo.com/gads?
t=ms&k=Sailing+schools&w1=Sailing+schools&
w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing
+ad
venture&w6=Sailing&c=6&s=122&.sig=nM_33Bwh2_UhuqSYWZR8Xw>
Sailing
instruction
t=ms&k=Sailing+instruction&w1=Sailing+scho
ols&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sai
lin
g+adventure&w6=Sailing&c=6&s=122&.sig=PLKTippWs7H3hJMQiiV1Dg>
Sailing
lesson
t=ms&k=Sailing+lesson&w1=Sailing+schools&w
2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+
adv
enture&w6=Sailing&c=6&s=122&.sig=BW-ssa-AtK1bKwgxZtYhsg>
Sailing course
t=ms&k=Sailing+course&w1=Sailing+schools&w
adv
enture&w6=Sailing&c=6&s=122&.sig=iJziK8qHrpaIJG_Q19twrg>
Sailing
adventure
t=ms&k=Sailing+adventure&w1=Sailing+school
s&w2=Sailing+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Saili
ng+
adventure&w6=Sailing&c=6&s=122&.sig=luRjwGYgtoRAVO_RIh446A>
Sailing
t=ms&k=Sailing&w1=Sailing+schools&w2=Saili
ng+instruction&w3=Sailing+lesson&w4=Sailing+course&w5=Sailing+adventu
re&
w6=Sailing&c=6&s=122&.sig=H5HiiLFUXHyIpCEv0TmINg>
YAHOO! GROUPS LINKS
Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer
than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter,
Thanks for the info Al. Didn’t think the lead keel shoud be a problem
but it did have bubbled paint on the bottom area which the yard had to
sand off before bottom painting. Guess it’s time to get a multi-meter
and start checking things out. Were the the shaft and strut bonded
on new Freedoms? Normally I would prefer each to be separate and
depend on its own zinc.
Bruce
NOt bethed near a steel quayside or anything like that. Near the end
of a dock in Cabrillo Marina in San Pedro. Diver did say that a motor
yacht on the end tie also seemed to be eating zincs more than normal.
Thanks for the responses
Bruce
— In freedomyachts2003@yahoogroups.com, “Michel Capel”
good luck,
<ajlorman@> wrote:
Bruce:
which is
problem.
everything
docked in a
Al Lorman
F30 Ab Initio
survey
informed
least
or
replaced
does
under
Foreward
either
first
message.
Bruce
SPONSORED LINKS
Sailing schools
+ad
Sailing
instruction
lin
Sailing
lesson
adv
Sailing course
adv
Sailing
adventure
ng+
Sailing
re&
YAHOO! GROUPS LINKS
Bruce:
I don’t know whether the shaft and strut are bonded. Mercifully, my F30 has had few electrolysis issues (compared to my prior Sabre, which ate zincs).
Al
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of brucestrtSent: Friday, February 10, 2006 10:56 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Electrolysis onF-28Thanks for the info Al. Didn’t think the lead keel shoud be a problembut it did have bubbled paint on the bottom area which the yard had tosand off before bottom painting. Guess it’s time to get a multi-meterand start checking things out. Were the the shaft and strut bondedon new Freedoms? Normally I would prefer each to be separate anddepend on its own zinc.Bruce
Posted by Folia Grace (fgrace2000@…>)
Bruce,
Had the same problem on F36. Epoxy coated the Keel lead and solved
the problem. Yard recommnended glassing over the keel lead, but I
did not go that far.
Regards,
Van
— In freedomyachts2003@yahoogroups.com, “brucestrt”
survey
informed
least
or
replaced
does
under
Foreward
either
first
message.
Bruce
