Emmylou Improvements
Hi - I have posted some pictures with comments at:
http://www.seanmulligan.com/Stories/Improvements/index.html
Yes, Emmylou has, and uses, a class staysail.
I haven’t tacked it to pole end yet, just sleeve.
Sean / Vivian
Emmylou 307
— In freedom21@yahoogroups.com, bill weber <billpeggyweber@…>
Look forward to pictures. I also need to replace my hatch. Did you
buy it at pompanette. If so. Are you happy with it?? Real
interested in your pc placement onboard. Do you have a staysail???
Posted by j32080@…> (j32080@…>)
Re: Putting a vent in the hatch. Sean, I did use the deck port for a Nicro solar vent. Photo: http://www.freedom21.info/images/bluemerle/BMDeckPortChangedToVent.jpg However, my vent didn’t extend that far down. You may still be able to get away with with you’ve got. There is a bit of room up there. So long as it clears the hatch. Careful measurements. You’ll need to change the 4" deck port anyway, so remove it and test it with a dry fit. Nice improvements. I fitted the area you use as your “nav station” as the galley stove. photo: http://www.freedom21.info/images/bluemerle/BMORIGO2000stove.jpg You could have both - just cut a board to go over the stove. What do you use for a stove / cooking? I.e., boiling water for tea or coffee while anchored or on a mooring. -John Sean Mulligan <quadmulligan@…> wrote: Hi - I have posted some pictures with comments at:http://www.seanmulligan.com/Stories/Improvements/index.htmlYes, Emmylou has, and uses, a
class staysail.I haven’t tacked it to pole end yet, just sleeve.Sean / VivianEmmylou 307— In freedom21@yahoogroups.com, bill weber <billpeggyweber@…> wrote:>> Look forward to pictures. I also need to replace my hatch. Did you buy it at pompanette. If so. Are you happy with it?? Real interested in your pc placement onboard. Do you have a staysail???
How low will we go? Check out Yahoo! Messenger’s low PC-to-Phone call rates.
