Exhaust Anti-Siphon Valve
Posted by noclams2000 (rsmcelroy@…>)
My F-30 has an anti-siphon valve in the storage compartment of my top step and
it’s
leaking. My boat yard couldn’t repair it so it looks like I need a new one.
Does anyone
know who makes this valve? Did Freedom make it? The boat yard says it’s not a
Yanmar
part and I would love to replace it with something that would fit in the same
location.
-Scott
There is a standard Volvo fitting for this: just goes into the water hose (?
diameter) so
would work for any engine, but, as with all Volvo parts, you may need to
re-mortgage your
house to buy one!
Gerald
it’s
Does anyone
a Yanmar
location.
-Scott
Hi Scott -
I changed the anti-siphon valve on our F45 this year for a host of reasons while ferretig out an engine problem. Ironically, the company that makes it is Scott Marine - and it is called a vacuum breaker. Try the web or your local supply or of machanic to order one.
john Ernst
S/V Destiny. out of Hertford, NC currently in Beaufort, SC on our way to the Bahamas -----Original Message-----From: noclams2000 <rsmcelroy@…>To: freedomyachts2003@yahoogroups.comSent: Sun, 27 Mar 2005 22:04:58 -0000Subject: [freedomyachts2003] Exhaust Anti-Siphon Valve
My F-30 has an anti-siphon valve in the storage compartment of my top step and it’s leaking. My boat yard couldn’t repair it so it looks like I need a new one. Does anyone know who makes this valve? Did Freedom make it? The boat yard says it’s not a Yanmar part and I would love to replace it with something that would fit in the same location.
-Scott
------------------------ Yahoo! Groups Sponsor --------------------~–> Help save the life of a child. Support St. Jude Children’s Research Hospital’s
‘Thanks & Giving.’
Click](http://us.click.yahoo.com/6iY7fA/5WnJAA/Y3ZIAA/A1TolB/TM%22%3E%3CB%3EClick) Here!
--------------------------------------------------------------------~-> Yahoo! Groups Links
<> To visit your group on the web, go to:
> To unsubscribe from this group, send an email to:
<*> Your use of Yahoo! Groups is subject to:
http://docs.yahoo.com/info/terms/
There was a discussion about this part on the list in the past. Apparently, it is no longer made. Mine leaks a little and I’m just living with it.
Al Lorman
F30 Ab Initio
-----Original Message-----From: noclams2000 [mailto:rsmcelroy@…] Sent: Sunday, March 27, 2005 5:05 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Exhaust Anti-Siphon ValveMy F-30 has an anti-siphon valve in the storage compartment of my top step and it’s leaking. My boat yard couldn’t repair it so it looks like I need a new one. Does anyone know who makes this valve? Did Freedom make it? The boat yard says it’s not a Yanmar part and I would love to replace it with something that would fit in the same location. -ScottThis email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Posted by mdurki (vaughan@…>)
I was the one who brought this up last year, and I got the last
replacements from Freedom. However, someone–I think Mark Edwards said
that the anti-siphon valve made by Vetus and sold by West Marine would
work as a replacement. The picture in the catalog looks a bit large to
fit in our step compartment, and I would like to know if anyone has
used it.
Assuming you are referring to the antisiphon valve on your exhaust
system. You can make your own. Place a bronze tee in the cooling
water injection line. Off the tee run a small dia. hose as high as
possible and connect a check valve oriented so as to block water
flowing from the engine. You can eliminate the check valve and
continue the run of small dia. hose back to a drain point such as a
tee in a deck scupper. The small dia hose prevents too much cooling
injection water bypass and provides all the siphon break you need.
— In freedomyachts2003@yahoogroups.com, “mdurki” <vaughan@i…>
would
large to
has
used it.
Thanks!
I saw that valve made buy Vetus but West Marine told me that it was back
ordered. I also
found “vented loops” made buy Forespar and Groco that might work. I e-mailed
Freedom
about this but they never answered me. Now that I know that they no longer
stock the old
antisiphon valve, I will go ahead and formulate a new plan…
would
large to
has
used it.
