Posted by davecheslow (Dave1nyl@…>)
Does anyone know where to get replacement weatherstrip for the
opening portlights on Freedom 21?
Dave Cheslow Freedom-21 #278 “Jersey Girl” sailing out of Monmouth
Boat club, Red Bank, NJ
I have a freedom 21 with the same problem. Did you look at west marine? My boat looks like it is a one piece screen imbedded into the porthole frame. My port collect water because of the angle only one of four leaks. West marine has shutters that you can caulk into the porthole to divert water but they are $50 apiece. I just bought my 21 and still learning. My forward hatch latch is broken and without tape comes open and leaks. I have to find a small hatch to replace. How long have you had your boat??
I’m still trying to figure out the spinnaker riggingdavecheslow <Dave1nyl@…> wrote:
Does anyone know where to get replacement weatherstrip for the opening portlights on Freedom 21?Thanks,Dave Cheslow Freedom-21 #278 “Jersey Girl” sailing out of Monmouth Boat club, Red Bank, NJ
Do you Yahoo!?
Yahoo! Mail - 50x more storage than other providers!
Posted by blueraven295 (blueraven1@…>)
Dave & Bill,
The opening ports are made by Beckson. See www.beckson.com for
parts. Keep the seal clean to avoid leaks.
For all basic F-21 info, see www.dwyergreen.com Rigging for all
lines is found in Commissioning Instruction.
The forward hatch is a Bomar "Gray Low Profile Molded Hatch.
WEST MARINE has them for $139.99 (117889)
Welcome to the F-21 World.
Nick,
Blue Raven
F-21, #295
— In freedomyachts2003@yahoogroups.com, bill weber
I’m still trying to figure out the spinnaker riggingdavecheslow <Dave1nyl@a…> wrote:
Boat club, Red Bank, NJYahoo! Groups SponsorADVERTISEMENT
var lrec_target=“_top”;var lrec_URL = new Array();lrec_URL[1]
= "http://us.ard.yahoo.com/SIG=129a7m5k7/M=296967.5106131.6227187.329
4649/D=groups/S=1705065792:HM/EXP=1089120626/A=2196952/R=0/id=flashur
l/SIG=1304ck1na/*http://www.sodaclubusa.com/referrer.asp?
redirect=rv_boat_camp.asp&referrer=0002_0015_0178_0002 ";var
link=“javascript:LRECopenWindow(1)”;var lrec_flashfile
= ‘http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/hm_ad_300x250_1.sw
f?clickTAG=’+link+‘’;var lrec_altURL
4649/D=groups/S=1705065792:HM/EXP=1089120626/A=2196952/R=1/id=altimgu
rl/SIG=1304ck1na/*http://www.sodaclubusa.com/referrer.asp?
lrec_altimg
= “http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/alternate_320x250_
061504.jpg”;var lrec_width = 300;var lrec_height = 250;
Yahoo! Groups Links
To visit your group on the web, go to:
http://groups.yahoo.com/group/freedomyachts2003/To unsubscribe from this group, send an email to:
freedomyachts2003-unsubscribe@yahoogroups.comYour use of Yahoo! Groups is subject to the Yahoo! Terms of
Service.
Do you Yahoo!?
Thanks very much, all. The F36/38 does have metal
strips around the
lights. Possibly aluminum, possibly brushed stainless
steel. I remember the 32’s now. That’s a little
different installation. Will try the Brasso fix before
replacing all the hazy lexan. But every seal is shot
and every openable port has begun to leak slightly. So
I’ve got to get those gasket-type strips fom somewhere
and pull and rebed the lot. I’ll call Mark at TPI
first, as someone suggested, and see what they know.
Thank you. It is time to restore the wood inside, but
no sense starting that until the leaks around the
ports are cured. All doable. And how
lovely she will be. Thank you for your experience.
Kind regards,
Jacqui Mac, Sparrow, Bellingham, WA
— blueraven295 <blueraven1@…> wrote:
Dave & Bill,
www.beckson.com for
parts. Keep the seal clean to avoid leaks.For all basic F-21 info, see www.dwyergreen.com
Rigging for all
lines is found in Commissioning Instruction.The forward hatch is a Bomar "Gray Low Profile
Molded Hatch.
WEST MARINE has them for $139.99 (117889)Welcome to the F-21 World.
Nick,
Blue Raven
F-21, #295— In freedomyachts2003@yahoogroups.com, bill weber
you look at west
imbedded into
of the angle only
you can caulk into
broken and
a small hatch to
out of Monmouth
Array();lrec_URL[1]
";var
lrec_flashfile
'http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/hm_ad_300x250_1.sw
f?clickTAG=‘+link+’';var lrec_altURL
";var
lrec_altimg
"http://us.a1.yimg.com/us.yimg.com/a/so/sodaclub/alternate_320x250_
061504.jpg";var lrec_width = 300;var lrec_height =
250;
Yahoo! Groups Links
to:
Yahoo! Terms of
Service.
Do you Yahoo!?
providers!
Do you Yahoo!?
Yahoo! Mail is new and improved - Check it out!
http://promotions.yahoo.com/new_mail
