Emergency Tiller for F30: A large diameter aluminum tube, probably black, with a small diameter aluminum pipe welded through it at about right angles at one end. Fits through the deck port (maybe 4" in diameter) on the little sitting shelf just behind the helm. Usually stored up high on the forward end of the seat locker, also attached by elastic cords. Foolishly never gave it a try at sea…but I am sure that it will be a real workout to steer a little F30 in a serious seaway ( (I would have modestly suggested to Garry Mull to put a little more rudder ahead of the center of rotation). Handle (tiller pipe) is very short…and as I remember (but please check me) will clear the wheel when installed. My only compensation for being so foolish for not practicing the use of the emergency tiller was that I removed the
bottom plywood cover off of the steering cable system (overhead, aft center end of the aft bunk) and checked it often. Also, removed plywood cover at the bulkhead right at the very aft end of the same bunk…and could see and quickly get to… the cable quadrant on top of the rudderpost. More open access (for a thin person with no claustrophobic tendencies) is available through the very aft end of the seat locker…but it would be a terrible spot to get to in a real emergency).Relevance: My best sailing friend just lost his boat last month and very very nearly lost his life because his wheel became disconnected from his rudder and his boat became uncontrollable as it was being blown ashore off the Maryland coast in a gale. He had no quick workaround…like an emergency tiller…or quick access to the cable system. Freedoms come equipped with both. Prevention, first;
proven back-up last. Neither; Well, at our ages, it could get a lot more thrilling than we can handle. FargoEx F30#12— On Sun, 7/20/08, bdachris2 <cwheddon@…> wrote:From: bdachris2 <cwheddon@…>Subject: [FreedomOwnersGroup] Re: F-30 Emergency Rudder HandleTo: FreedomOwnersGroup@yahoogroups.comDate: Sunday, July 20, 2008, 8:03 PM
Bob, if you’re still interested let me know. I’ll send you a photo of my emergency tiller
— In FreedomOwnersGroup@ yahoogroups. com, “lance_ryley” <lance_ryley@ …> wrote:
Hi Bob,
don’t know about on the F-30, but on Bright Star (F-40 CK), the
emergency tiller was in the port cockpit lazarette. It was suspended
under the seat by a piece of truck tire inner tube at one end and bungy
cords along its length. To use it, you’d have to take off the wheel
(presumably already useless), slide the tiller bracket over the head of
the outboard rudder, and open the hydraulic steering bypass.
On Glory (Freedom 45), the emergency tiller is located under the aft
cabin bunk right by the steering quadrant. To get to it, you have to
ditch the mattress, pull up the under-mattress boards, and then stick
the socket head over the rudder shaft head. Only problem is that, being
a center cockpit, you’d have to open the hatch over the bed just to be
able to hear the person in the center cockpit who could actually see
where you were going, and then… well… it would probably take two to
steer it and I hope I never have to find out.
Lance
— In FreedomOwnersGroup@ yahoogroups. com, “Bob Weeks” <rweeks6508@ >
Can anyone tell what the emergency handle looks like? I been looking
through the boat and so far all I have found is parts for a AutoHelm
plus
belts, brand new bilge pumps, tons of Yanmar spare parts and a brand
new
never used FlexoFold prop but no emergency rudder handle. If anyone
has a
picture that would be nice.
Bob
