Posted by Jeff Chale (jwchale@…>)
I will be replacing my shaft seal and the cutlass bearing when I haul next month and am curious if anyone can tell me if I am going to have to drop the rudder to pull the shaft? Just tryng to get prepared.
Thanks for your help.
Jeff__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Posted by Richard Fontaine (rafontaine1@…>)
FYI - I just removed the shaft from my F36. On the F36 the prop will not clear the rudder. So I removed the transmission and bell housing thinking I could move it forward enough to get it pass the strut. No such luck. I needed another inch. So I removed the cutlass bearing with the shaft as far forward as it would go then I had enough clearance between the strut and the shaft to angle the shaft enough to just clear the rudder. I will be re-installing shaft, syntron seal, cutlass bearing etc. in the same order as removed . I hope!
Rich Fontaine
s/v Liberte, F36
Jeff
__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com __________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
Removing shaft.
On both a Freedom
32 (Hoyt) and a Freedom 36, I was able to remove the shaft, On the 32, it
would pass the rudder with a max 2 blade feathering and on the 36 removing the
prop and a little persuasion and the rudder adjusted for minimum clearance.
Brian
-----Original Message-----
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Richard Fontaine
Sent: Friday, May 13, 2005 5:43 PM
F-30 Prop Shaft Question
Rich Fontaine
s/v Liberte, F36
Portsmouth, RI
Jeff Chale
prepared.
Jeff
Do You Yahoo!?
Do You Yahoo!?
Posted by Mike Kovacic (sailslakemichigan@…>)
I own a F36 and replaced the cutlass bearing a while back. I did remove the rudder to do so and it was not a difficult task.
Mike
RefugeBrian Guptil <sailordude@…> wrote:
Removing shaft.
On both a Freedom 32 (Hoyt) and a Freedom 36, I was able to remove the shaft, On the 32, it would pass the rudder with a max 2 blade feathering and on the 36 removing the prop and a little persuasion and the rudder adjusted for minimum clearance.
Brian
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Richard FontaineSent: Friday, May 13, 2005 5:43 PMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] F-30 Prop Shaft Question
Rich Fontaine
s/v Liberte, F36
Jeff
Yahoo! Mail Stay connected, organized, and protected. Take the tour
