There is an F-30 that may be going pretty cheap. It’s a shoal draft
which I’m not fond of. Has anyone sailed and compared a std draft F-
30 and a shoal draft model? Or has anyone buddyboated and been able
to draw any comparison? We don’t sail in thin water and I’ve always
preferred to avoid the compromise of shoal draft models.
I’m also curious about how the galley sink drains. On this
particular boat the galley drain is led all the way to thru-hull
under the port settee. Isn’t there a thruhull closer to the
waterline? Seems weird to put a sink near centerline where it
belongs but not have the sink drain to a thru hull closer to the
centerline.
I’m more of a ketch person but this cat sloop was kind of intriguing
especially for at the price I could probably pick it up.
Dave:
I have an “shoal draft” F30 and I’ve never had the opportunity to sail a deep draft model. However, the shoal draft model is not nearly as shoal as advertised. I measured the draft of 3 shoal draft models on the hard when I was looking and found that the draft was a lot closer to 5’ than it was to 4’6". In any event, I can testify that my F30 is an amazingly stiff boat, whatever the keel depth.
The galley sink on my boat (hull no. 70) drains through a through hull directly under the sink.
Al Lorman
F30 Ab Initio
-----Original Message-----From: Dave_Benjamin [mailto:dave_benjamin@…] Sent: Wednesday, February 02, 2005 12:14 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] F-30 QuestionsThere is an F-30 that may be going pretty cheap. It’s a shoal draft which I’m not fond of. Has anyone sailed and compared a std draft F-30 and a shoal draft model? Or has anyone buddyboated and been able to draw any comparison? We don’t sail in thin water and I’ve always preferred to avoid the compromise of shoal draft models.I’m also curious about how the galley sink drains. On this particular boat the galley drain is led all the way to thru-hull under the port settee. Isn’t there a thruhull closer to the waterline? Seems weird to put a sink near centerline where it belongs but not have the sink drain to a thru hull closer to the centerline.I’m more of a ketch person but this cat sloop was kind of intriguing especially for at the price I could probably pick it up.This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Dave:
I have a Mull F28, not a perfect
comparison, but close. The 30 is pretty much the same hull, engine, rig,
systems, etc, just has an after cabin and 2 more feet. The F28 is draft of 4’6”,
it is quite stiff, I have sailed in as much as 30 knots of apparent wind
without a reef, though generally put the 1st reef in in 18-22 knots
apparent to get her back upright. I have heard the 30’s are similarly stiff.
I would think you would be getting a pretty stiff boat.
Douglas M. Payne
Tatum Partners
480-614-4915 Office
480-236-4561 Mobile
480-614-4916 Fax
doug.payne@…
TATUM PARTNERS
computers.
Sent: Tuesday, February 01, 2005
10:14 PM
Questions
It’s a shoal draft
and been able
models.
On this
way to thru-hull
closer to the
centerline where it
closer to the
centerline.
kind of intriguing
it up.
