F-35 Hoyt jib boom coupler
Posted by edwardcywinski (ecywinski2@…>)
This spring I will be diving in attempt to find the part that couples
my hoyt jib boom to the forestay. The piece flew into (!) the water
as I was dismounting the staysail for the winter. If there is anyone
who has reconfigured their staysail to a furler, and who may have
this part, I would be interested in acquiring it if unable to
retrieve my own. (It is a stainless, triangular flat piece that cups
the forestay and bolts to the forward end of the jib boom. It works
as a slider as one hoists the sail, pulling the jib boom into sailing
position.)
You can get the part from Freedom or Berig sails. Just give them the
forestay size.
— In freedomyachts2003@yahoogroups.com, “edwardcywinski”
couples
water
anyone
cups
works
sailing
position.)
Indeed, both Freedom and Bierig Sailmakers have the part, but if that is the part you need, you have a CamberSpar jib, not a Hoyt jib boom. The Hoyt is the one that physically attaches to the deck sort of like an “L” on its side. The CamberSpar was invented by Dave Bierig, Bierig Sailmakers, Erie, PA, 814-459-8001. There’s a small hole in the part which can be used to attach a small piece of line, the other end of which is loosely tied to the forestay. If you do that, you never need another one.
Al Lorman
-----Original Message-----From: macks011 [mailto:macks04@…] Sent: Thursday, March 17, 2005 3:53 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: F-35 Hoyt jib boom couplerYou can get the part from Freedom or Berig sails. Just give them the forestay size.— In freedomyachts2003@yahoogroups.com, “edwardcywinski” <ecywinski2@c…> wrote:> > This spring I will be diving in attempt to find the part that couples > my hoyt jib boom to the forestay. The piece flew into (!) the water > as I was dismounting the staysail for the winter. If there is anyone > who has reconfigured their staysail to a furler, and who may have > this part, I would be interested in acquiring it if unable to > retrieve my own. (It is a stainless, triangular flat piece that cups > the forestay and bolts to the forward end of the jib boom. It works > as a slider as one hoists the sail, pulling the jib boom into sailing > position.)This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Posted by ecywinski2@… (ecywinski2@…)
Thanks for your reply and for the information. Regards, Ed
-------------- Original message -------------- You can get the part from Freedom or Berig sails. Just give them the forestay size.— In freedomyachts2003@yahoogroups.com, “edwardcywinski” <ecywinski2@c…> wrote:> > This spring I will be diving in attempt to find the part that couples > my hoyt jib boom to the forestay. The piece flew into (!) the water > as I was dismounting the staysail for the winter. If there is anyone > who has reconfigured their staysail to a furler, and who may have > this part, I would be interested in acquiring it if unable to > retrieve my own. (It is a stainless, triangular flat piece that cups > the forestay and bolts to the forward end of the jib boom. It works > as a slider as one hoists the sail, pulling the jib boom into sailing > position.)
Al,
Thanks for your your reply. You are correct. My fuzzy description was inaccurate in that the jib must be correctly identified as a camberspar, not as a “hoyt”. Freedom did not have the part. I will be contacting Bierig Sailmakers. Your information is of great value. Regards, Ed Cywinski
Al Lorman
My pleasure. Dave Bierig is a very nice guy. He’s the one who told me about tying the part on. (It was missing when I bought my boat.)
Al
-----Original Message-----From: ecywinski2@… [mailto:ecywinski2@…] Sent: Thursday, March 17, 2005 11:30 AMTo: freedomyachts2003@yahoogroups.comSubject: RE: [freedomyachts2003] Re: F-35 Hoyt jib boom coupler
Al,
Al Lorman
-----Original Message-----From: macks011 [mailto:macks04@…] Sent: Thursday, March 17, 2005 3:53 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: F-35 Hoyt jib boom couplerYou can get the part from Freedom or Berig sails. Just give them the forestay size.— In freedomyachts2003@yahoogroups.com, “edwardcywinski” <ecywinski2@c…> wrote:> > This spring I will be diving in attempt to find the part that couples > my hoyt jib boom to the forestay. The piece flew into (!) the water > as I was dismounting the staysail for the winter. If there is anyone > who has reconfigured their staysail to a furler, and who may have > this part, I would be interested in acquiring it if unable to > retrieve my o! wn. (It is a stainless, triangular flat piece that cups > the forestay and bolts to the forward end of the jib boom. It works > as a slider as one hoists the sail, pulling the jib boom into sailing > position.)This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail. This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Al,
I agree: just contacted him. He’s sending the part. It will save me the trouble of a dive and groping around in the murky Chesapeake waters. Regards, Ed
Al
Al,
Al Lorman
Posted by JoelR (ohso2001@…>)
Same thing happened to me a few years back. I
purchased a new one from Freedom. They have the part.
part that couples
into (!) the water
If there is anyone
who may have
unable to
boom. It works
boom into sailing
position.)
Do you Yahoo!?
Yahoo! Small Business - Try our new resources site!
http://smallbusiness.yahoo.com/resources/
