Posted by jborigin (jborigin@…>)
I was curious about the length of the gumount yard on a F21.
Also, what is the meaning of the number on the mainsail, does it
happend to correspond with the hull number?
Thank you,
Jose
84 f 21
Jax, fl
Thank you,
Jose
84 f 21
Jax, fl
Posted by Nick (blueraven1@…>)
Pole Length = 12’ 0" (www.dwyergreen.com, factory info, sail
specs, last page)
Hull Numbers
Posted by Mark Edwards on November 07, 1998 at 20:11:58:
In Reply to: Hull Numbers posted by Denis Neumann on September 18,
1998 at 18:48:12:
Hi Dennis,
I have had trouble receiving updates to the message board at work
and have been very busy at shows and with subsequent follow up.
Sorry for this delayed response.
Each line proceeds in a different way but Brian summed up the
general practice best. The first three digits: TSP or FYC are for
the manufacturer with the latter on all boats built after the sale
of Freedom yachts in 1989. Usually there will follow a model ID such
as 36 or 38 for Freedom 36 and then three digits for the sequential
hull #. The last four digits of the 12 digit HIN are for the month
the hull was molded starting in January with an “A” and February
with a “B” etc and the the year the hull was molded followed by the
model year. There are some lines where numbers were skipped and the
Freedom 36 is a good example where the first boats were only even
numbers through hull # 10. Hope this helps.
Mark Edwards
Nick
Blue Raven
F-21, #295
— In freedomyachts2003@yahoogroups.com, “jborigin” <jborigin@a…>
happend to correspond with the hull number?Thank you,
Jose
84 f 21
Jax, fl
Posted by jborigin@… (jborigin@…)
well my sail number is number 1 I will have to check the hull after reading about the HINS
thanks for the information
Posted by gaprior (gaprior@…>)
Hi Jose-
Hopefully your sail number and hull number match! You can find more
info on HINs on the ‘Files’ page of the group:
http://groups.yahoo.com/group/freedomyachts2003/files/
Look on page 11 on Rick’s post “Freedom Manuals”. The numbering
system seems to have changed over the years…
-Greg
Jose
84 f 21
Jax, fl
