F25 lazy jack attachment
Posted by fgljff (fgljff@…>)
The line drawing for the F25 lazy jacks is a little hard to make out. I can see
that the ropes are
reaved through the block on the wire, but how do they attach to the boom? Are
they just
looped under the boom with little tails tied at the loops? Can anyone help?
I can see that the ropes are
boom? Are they just
help?
On my F25 the forward line loops thru’ a pad eye on the underside of
the boom and the aft lines are tied to a cleat. When you rais the
main, you have to be careful that the battens don’t catch. Usually
only the first can catch, the others are long enough not to catch.
Harv F-25, #50,'82
There is a single line that does it all. Tie it through the hole in
the cleat at the rear using a bowline, thence to the block on the
wire, then through the fitting on the underside of the boom forward,
then through the block on the other side, and then to the cleat where
all this started. The cleat permits some adjustment as to how high
the boom is supported. Herm
out. I can see that the ropes are
boom? Are they just
Thanks Herm. I’m going to try rigging it that way. I figure I’ll use some 5/16
sta-set.
<hschiller2@…>
boom? Are they just
thanks Harv. As I mentioned to Herm, I’m going to rig it that way with some 5/16
sta-set.
boom? Are they just
help?
Harv F-25, #50,'82
That seems to be the size I recall… I now have a Mull 28, but the
lazy jacks are largely identical. Herm
some 5/16 sta-set.
— In
Herman and Gail Schiller <hschiller2@…>
boom? Are they just
anyone help?
