I was in a race last Sunday. The start was a downwind run. We kept up and almost
overtook
some J-80s. But when we rounded the mark and began the upwind leg, we fell
behind. Way
behind.
What could I have done to get better upwind performance? It was light air. Also,
the boat
wouldn’t point very hight.
What is your PHRF or Portsmouth rating? The J80s and most other boats
should be giving you a lot of time. Were you using a staysail? The
right type-and size-can make a great difference. The wrong size, and
type, will not help much-if at all. It has taken 2 years of trial and
error for me to get to the point that my round mast F25 is
competitive with most boats. The J80s and other faster boats still
beat me upwind, sailing faster and pointing higher; however I often
beat them on corrected time. Charlie
up
and almost overtook
we
fell behind. Way
behind.
light
air. Also, the boat
My phrf new england is 179. I think I can reapply and get it raised, however,
to around 201.
No, I wasn’t using the staysail. I probably should have. I have two staysails.
One is small and
the other much larger. They have poles (both of which are bent) which are
shackled to the
gunmount sleeve. I guess this is standard. I’m not really sure when to use
which. Also, where
do you place the telltales on your sail? Someone told me that with the wing mast
you can
actually place set of telltales on the aft edges of the mast itself. Then a few
more on the sail.
raised, however, to around 201.
staysails. One is small and
which are shackled to the
to use which. Also, where
the wing mast you can
itself. Then a few more on the sail.
I’ve got a 120% j shackled down to the deck and it really improves the
pointing power by about 10%. To make for far easier handling I’ve rigged
a nice furling system using the largest Barton furler and swivel top
unit available, approx £60.00. This winter I’m fitting running
back-stays to increase jib luff tension, that will finish the job!
