I have the same problem and just removed the rubber part (its called a gaither) so I could take it to a marine supply store and match it for a replacement. I know the pump is a Whale, but I too have never found a model number or name. I’ll share whatever I learn.
Al Lorman
F30 Ab Initio
-----Original Message-----From: Doug Payne [mailto:doug.payne@…] Sent: Saturday, January 22, 2005 12:09 PMTo: freedomyachts2003@yahoogroups.comSubject: RE: [freedomyachts2003] F30 manual bilge pump
Don’t have model numbers but I replaced several parts on my Whale manual bilge pump on my 87 F 28 last year. The outer boot definitely doesn’t effect the pumping but is indication of potential trouble with the internal bladder that does. Mine was a Whale, and I got replacement parts on a close out table at west marine for about $10. ( my wife didn’t appreciate my glee at finding the correct parts cheap!) . I removed the pump took it in to West Marine (mega store in Marina Del Ray CA that has most of their line) and matched it up. They stock quite a lot of Whale replacement parts. Wound up replacing the internal bladder, kept the old one as a spare as it was still quite functional, replaced the outer boot and put a newer plastic Whale cover on the outside of the pump in the Cockpit. This new cover has a little door that opens upward and exposes the place for the handle, looks more modern and works quite well. That new door fits the older pumps and newer models as well. The internal parts fit my old pump and newer models as well. You may have to do some further research to get part numbers, I couldn’t find numbers on the pump body. There is a Whale distributor in San Diego, I am sure on the east coast as well. Whale is British company if I member correctly and have a website.
Douglas M. Payne
Tatum Partners
480-614-4915 Office
480-236-4561 Mobile
480-614-4916 Fax
doug.payne@…
TATUM PARTNERS
This electronic message is intended for the person or entity to which it is addressed and may contain confidential and/or privileged information. Any review, dissemination, copying, printing, or other use of this electronic message by persons or entities other than the addressee is prohibited. If you received this electronic message in error, please contact the sender immediately and delete the electronic message from any and all computers.
-----Original Message-----From: seychellois_lib [mailto:seychellois_lib@…] Sent: Saturday, January 22, 2005 8:08 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] F30 manual bilge pump
Last time I was on the boat I noticed pretty serious deterioration ofthe external rubber bladder on my manual cockpit bilge pump. OK, to behonest I have noticed this for several years. The pump works fine butit is an absolute certainty that when I need this pump in an emergencythe bladder will decide to fail. So, does anyone know what the manualpump model and mfg is? In the past I,ve crawled around the lazarette to take a look at theback of the pump to find a make/model and no dice. Far as I can tellits not printed on the visible casing.I live in Alberqueque and the boat’s in Cali. I’d like to mail order arebuild kit prior to my next trip out. If anyone has any input itwould be appreciated.MikeJacquelineF30 #3This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
