Posted by Payne, Doug (doug.payne@…>)
Thanks Al, a sail trim guide would be great!!!
Douglas M. Payne
Tatum Partners
480-614-4915 Office
480-236-4561 Mobile
480-614-4916 Fax
doug.payne@…
TATUM PARTNERS
This electronic message is intended for the person or entity to which it is addressed and may contain confidential and/or privileged information. Any review, dissemination, copying, printing, or other use of this electronic message by persons or entities other than the addressee is prohibited. If you received this electronic message in error, please contact the sender immediately and delete the electronic message from any and all computers.
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Lorman, Alvin J.Sent: Monday, October 17, 2005 1:17 PMTo: freedomyachts2003@yahoogroups.comSubject: RE: [freedomyachts2003] F30 Sail Trim
Doug:
Thanks for sharing your tactics. Steve Haarstick, from whom I bought my new sails, contacted me offline with some suggestions, which I’m sure he wouldn’t mind my sharing:
Al,
I read your e-mail today, and while I’m not sure how the main was trimmed, here are a few tips to remove excessive weather helm in heavy air.
1.) When reefing the main, make sure that the reef line is winched in very tight, so that the span between the reef tack and reefed clew is FLAT. If you are using a stretchy reefing line, this will stretch out after you sheet in, and the bottom of the sail will bag out to leeward. Even though the area is reduced, the boat will have too much helm if the main is not flat low.
2.) Ease the traveler down to leeward so that the boom is out to the leeward side of the transom.
3.) Don’t sheet the main in too hard. It is better to let the top of the sail twist out to leeward, even “floating” the top third in the puffs. When in doubt, sight from under the boom up to the top batten. The sail should be flat, and the back half of the batten should be about 10-15 degrees to LEEWARD of the boom.4.) Keep the heel at 20 degrees or less, as the Freedom 30 will develop more weather helm the further it heels. This is due to the relatively narrow bow and wide transom.
Keep the suggestion coming, folks. I think I’ll do an F30 sail trim guide when this is all done.
Al
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Payne, DougSent: Monday, October 17, 2005 3:06 PMTo: freedomyachts2003@yahoogroups.comSubject: RE: [freedomyachts2003] F30 Sail Trim
Those with a lot more experience than me may have more learned responses, but I have sailed my Mull 28 in up to 35 knots with one reef. Let the traveler down all the way to the lee side, crank down the boomvang and main sheet to flatten the sail, as the wind increase leave some twist on top to spill air, as the wind speed gets higher yet, ease the main further to spill more air. It is not pretty, but it works. From all I have read in this forum on these boats, one reef should be ok in 15-20 knots, it is for me. Some days I don’t even reef till over twenty. The 28 and 30 are very similar. Hope I can learn from some of the other posts you get on this topic. It is a good one!
Douglas M. Payne
Tatum Partners
480-614-4915 Office
480-236-4561 Mobile
480-614-4916 Fax
doug.payne@…
TATUM PARTNERS
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of ajlormanSent: Monday, October 17, 2005 7:55 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] F30 Sail Trim
I had a lovely sail on the Chesapeake on Saturday in 15-20 kt winds, but I could not balance the boat. I had one reef in the main, but it took constant attention to the helm to keep a course and the slightest wind puff caused the boat to head into the wind. She is generally much better behaved in light air. Can anyone give me any guidance on this? What am I doing wrong? Or is this normnal for a Freedom? Many thanks.Al LormanF30 Ab Initio=00
