Posted by katorpus (jrb@…>)
Don’t plumb the bilge pump into the sink drain or the head discharge
line.
If the thru hull gets closed off, you won’t be doing anything but
recirculating the water inside the boat (after the sink overflows
into the cabinetry)
Likewise, if the head discharge thru hull gets closed or clogged,
you’ll backfill the head. Also, you’ll likely plug up the bilge pump
discharge with “stuff” from the head discharge line.
Better it should have its own dedicated discharge line. It doesn’t
HAVE to be above the water line, but it will be less likely to clog
up with barnacles and such and you can monitor the outflow. If it’s
below the water line, it’ll need a seacock (which might get
inadvertently closed off).
Mine’s tee-d into the raw water discharge line from the engine, up
pretty high on the downward slope to the discharge end. (Factory
design).
Put in a loop as discussed elsewhere.
Something to remember when “bailing with a bucket”…
If the sink discharge line is open (at the seacock), you can dump it
in the sink instead of overboard…likewise into the head (but you
have to flush that). If your sink normally “drains slowly”, you
should clear the drain lines anyway.
Otherwise, if the cockpit drains are flowing, you can dump it over
the bridge deck into the cockpit.
Sometimes these things aren’t intuitive in times of crisis.
— In FreedomOwnersGroup@yahoogroups.com, Weaver Roger
<rogerweav@…> wrote:
Bob,Lance,& Al,
Re Bilge pump, F30,
I do not have an auto bilge pump installed, would like to add this
important
safety feature during lay up this winter.
I have always used the manual pump located port side cockpit area.
Works fine
except it would be exhausting in an ER.
Question: I do not have three discharge fittings as Bob described
on his F30
near the head (port side)only two. Head vent and sink discharge.
If I install a bilge pump can I splice into the head sink discharge
line with
back check values on each line or shd I plan to drill out and
install a third
discharge line at that location spec for bilge pump?
Regards,
Roger
Boardwalk for $500? In 2007? Ha! Play Monopoly Here and Now (it’s
updated for today’s economy) at Yahoo! Games.
http://get.games.yahoo.com/proddesc?gamekey=monopolyherenow
