Posted by Borelmfg (borelmfg@…>)
Bob,
Yes I did use the drill to make a small channel, but my toe rail was not 3/8 thick. I would guess more like 1/8" on the flat part that bolts the the deck.
Regards
Van
Sent: Tuesday, May 13, 2008 6:42 PM
Subject: RE: [FreedomOwnersGroup] F30 - Two Questions
Ok I reread what you wrote and I misunderstood. I thought you drilled a hole under the toe rail. The problem is the toe rail is close to 3/8 thick so it dams quite a bit of water. And yes your drilled hole would drain the water to the level of the thickness of the toe rail and I guess you could take dremel tool and grind a small channel to the hole even grind the hole further down. I guess during the warm period it not going to sit there very long anyway.
Bob
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of BorelmfgSent: Tuesday, May 13, 2008 9:25 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] F30 - Two Questions
No, Just left it raw. No major corrosion developed.
van
Sent: Tuesday, May 13, 2008 6:05 PM
Did you have to coat the hole with anything?
Bob
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of BorelmfgSent: Tuesday, May 13, 2008 4:55 PMTo: FreedomOwnersGroup@yahoogroups.comSubject: Re: [FreedomOwnersGroup] F30 - Two Questions
Bob,
Have no suggestion for #1. On #2, the F36 has the same issue. I drilled 1/4" holes in the vert. part of the toe rail as low as possible. That allowed most water to drain. The remainder would evaporate. This is one design flaw of freedoms. At least they were consistent across all products.
Regards,
Van
Sent: Tuesday, May 13, 2008 1:02 PM
Subject: [FreedomOwnersGroup] F30 - Two Questions
- the engine throttle and transmission shifter. How do you get the chrome cover off the shifter so I can take the whole unit out? I can pull the handle out of the chrome piece rather easy and the disengage transmission knob screws out easily also but that is where easy stops! Now to get the cover off any ideas?
- On the f-30 water on the deck accumulates by the forward area of the cockpit. It does not drain aft. And if it did then it would hit the 1/4" high teak piece across the back. I an only to chisle out a small canal next to the cleat to give it a opening overboard but not sure what to do about the puddling on either side of the cockpit.
Bob
