F33 Mast
Posted by daniel.oshaughnessy (daniel.oshaughnessy@…>)
Hi Freedom Folks!
My 1981 Freedom 33 has some impact damage on the leading edge of the
main mast; adjacent to the wishbone.
I’m not too familiar with repairs to carbon masts. Any hints or info
regarding suitable aluminum poles (wall thickness of ali mast for
example) and perhaps a supplier in the Chesapeake bay area.
Many Thanks
Dan
Daniel,I own a F33 , 1981 also. (Hull No 32) Be advised that I found the thickness of the carbon fiber layup to be between 1/8 and 3/16 " at deck level. (measured the stump of the broken stick)I replaced it with an aluminum pole, made by Pole Products of New Jersey.That was in 1997. Been sailing thousands of miles in the Caribbean since then, and that stick is doing fine. Cost at that time was $3500, delivered in Miami.“daniel.oshaughnessy” <daniel.oshaughnessy@…> wrote: Hi Freedom Folks! My 1981 Freedom 33 has some impact damage on the leading edge of the main mast; adjacent to the wishbone. I’m not too familiar with repairs to carbon masts. Any hints or info regarding suitable aluminum poles (wall thickness of ali mast for example) and perhaps a supplier in the Chesapeake bay area. Many Thanks Dan
No need to miss a message. Get email on-the-go with Yahoo! Mail for Mobile. Get started.
Hi Daniel,
Both my F44 masts were damaged by leaning against an overhead
powerline. Several experts said the repairs were easy to do. So I
wouldn’t aim for replacing your CF mast if it mas minor damage. A
good resin and fiber company can do the job.
— In freedomyachts2003@yahoogroups.com, “daniel.oshaughnessy”
Hi Freedom Folks!
Many Thanks
Dan
Repair it ! Not difficult,epoxy and appropriate fibers. Does not matter if becomes a little thicker. It still will be half the weight of alloy. Healing moment and stability would be affected with much heavier alu. mast.Frank Minelli <myslo@…> wrote: Daniel,I own a F33 , 1981 also. (Hull No 32) Be advised that I found the thickness of the carbon fiber layup to be between 1/8 and 3/16 " at deck level. (measured the stump of the
broken stick)I replaced it with an aluminum pole, made by Pole Products of New Jersey.That was in 1997. Been sailing thousands of miles in the Caribbean since then, and that stick is doing fine. Cost at that time was $3500, delivered in Miami.“daniel.oshaughnessy” <daniel.oshaughnessy@yahoo.com> wrote: Hi Freedom Folks!My 1981 Freedom 33 has some impact damage on the leading edge of themain mast; adjacent to the wishbone.I’m not too familiar with repairs to carbon masts. Any hints or inforegarding suitable aluminum poles (wall thickness of ali mast forexample) and perhaps a supplier in the Chesapeake bay area.Many ThanksDan No need to miss
Ask a question on any topic and get answers from real people. Go to Yahoo! Answers.
How significant is the damage and how did
it occur?
Alan F-33 Hull # 51 1982
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of andre laviolette
Sent: Saturday, March 10, 2007
8:42 AM
F33 Mast
Repair it
Frank Minelli
<myslo@yahoo.com> wrote:
Daniel,
Hi Freedom Folks!
area.
Many Thanks
Dan
on-the-go
Get
started.
Yahoo! Answers.
Thnks, Michel
This message board and it’s members are great.
Always ready for a quick and useful response.
I’ll post some pic’s of the damage and eventual repairs or replacement
if necessary.
Thanks again
Dan
<michel.capel@…> wrote:
Hi Daniel,
daniel.oshaughnessy@ wrote:
Hi Freedom Folks!
Many Thanks
Dan
Hi Allan,
The damage is apparantly impact damage causing delamination ot the outer
shell and exposing some fibres.
Don’t know how it occured as I bought the boat like this (but that is
another story!)
Regards
Dan
— In freedomyachts2003@yahoogroups.com, “Alan Kusinitz”
<akusinitz@…> wrote:
How significant is the damage and how did it occur?
laviolette
Sent: Saturday, March 10, 2007 8:42 AM
Subject: Re: [freedomyachts2003] F33 Mast
matter if
Healing
Frank Minelli myslo@… wrote:
Daniel,
Jersey.
since
delivered in Miami.
“daniel.oshaughnessy” daniel.oshaughnessy@… wrote:
Hi Freedom Folks!
Many Thanks
Dan
http://us.rd.yahoo.com/evt=43910/*http:/mobile.yahoo.com/mail
on-the-go
started.
http://ca.answers.yahoo.com Go to Yahoo! Answers.
The reason I asked about the extent of the
damage was for two reasons. First is the possibility it is more extensive then
you can see from the outside. You can examine most of the mast from the inside
when its out of the boat with a good flashlight. The outer skin of the mast is
gelcoat and fiberglass cloth and is not really structural (only for compression
purposes) or so I was told.
The second reason is that on my 33 the rig
was converted from wishbones and wraparound sails to straight booms and tracks.
I am not the original owner but was told this retrofit was done at Freedom.
The gooseneck is through bolted to the
mast. To do this they cut a whole in the front of each mast so they could
insert and hold the bolts. They put an aluminum plate over the hole (not
structural) and its easily removable for inspection or repair purposes.
With so many people concerned about
putting additional screw holes in the mast I was surprised Freedom had
put such large holes in the masts. I spoke to several carbon fiber mast
experts. The consensus was it was okay especially on the forward face of the
mast at this location. I have seen no stress cracking or other signs of
deterioration at the corners of this opening (and the boat has been surfing
over 10 knots and in winds up to slightly over 40 knots) or on the inside of
the mast. The bolts and nuts holding the gooseneck also show not wear around
them.
So my conclusion is that the fear of some
small holes or a small localized area of impact damage in similar locations is
not an issue.
I did consider glassing the opening but was told that it would only be cosmetic
unless I beveled the underlying carbon fiber edges back quite a ways. I felt
that doing this might reduce strength rather then add to it.
Alan
F-33 Hull
#51 1982 SEAPR
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of daniel.oshaughnessy
Sent: Monday, March 12, 2007 5:50
AM
F33 Mast
Hi Allan,
another story!)
Regards
Dan
“Alan Kusinitz”
Alan F-33 Hull
51 1982
On Behalf Of andre
laviolette
matter if
Healing
Daniel,
Jersey.
since
delivered in Miami.
Hi Freedom Folks!
area.
Many Thanks
Dan
on-the-go
Get
started.
I agree with Alan’s observations about making holes in CF masts; you
can do it, it’s not a big deal.
When planning repairs to both my damaged CF masts (they had sawcuts
near the top ends going about half into the masts) I asked three
renowned Dutch carbon fiber mast makers for an opinion and they came
all with the same story. Repairs are easy as long as you have the
experience, the right materials and the right working conditions
(mainly ambient temperature). The repair was not expensive.
I also asked about drilling and tapping holes. They all said that if
the wall thickness is enough, you can drill and tap thread and use
machine screws and locktite. Is you figure the wall is not thick
enough to provide the meat for a screw, use large stainless steel
rivets. Aluminum rivets are too soft they said, they will stretch
under load and start moving over time, wearing out the hole from the
inside with the blob at the in-mast end of the rivet.
I also asked about corrosion, but they were puzzled about that
question and said they never found that to be a problem with CF.
Perhaps because of the use of resin to cover the carbon?
My original 25 year old mizzen has an aluminum topplate glued in and
there are no signs of corrosion of the CF mast. Of course, you see
the normal corrosion where stainless steel meets aluminum.
Best,
The reason I asked about the extent of the damage was for two
reasons. First
is the possibility it is more extensive then you can see from the
outside.
You can examine most of the mast from the inside when its out of
the boat
with a good flashlight. The outer skin of the mast is gelcoat and
fiberglass
cloth and is not really structural (only for compression purposes)
or so I
was told.
The second reason is that on my 33 the rig was converted from
wishbones and
wraparound sails to straight booms and tracks. I am not the
original owner
The gooseneck is through bolted to the mast. To do this they cut a
whole in
the front of each mast so they could insert and hold the bolts.
They put an
aluminum plate over the hole (not structural) and its easily
removable for
With so many people concerned about putting additional screw holes
in the
mast I was surprised Freedom had put such large holes in the
masts. I spoke
to several carbon fiber mast experts. The consensus was it was okay
especially on the forward face of the mast at this location. I
have seen no
stress cracking or other signs of deterioration at the corners of
this
opening (and the boat has been surfing over 10 knots and in winds
up to
slightly over 40 knots) or on the inside of the mast. The bolts
and nuts
holding the gooseneck also show not wear around them.
So my conclusion is that the fear of some small holes or a small
localized
area of impact damage in similar locations is not an issue.
only be
cosmetic unless I beveled the underlying carbon fiber edges back
quite a
ways. I felt that doing this might reduce strength rather then add
to it.
Alan
F-33 Hull #51 1982 SEAPR
daniel.oshaughnessy
Sent: Monday, March 12, 2007 5:50 AM
Subject: [freedomyachts2003] Re: F33 Mast
Hi Allan,
outer
is
another story!)
Regards
Dan
— In freedomyachts2003@ <mailto:freedomyachts2003%
40yahoogroups.com>
From: freedomyachts2003@ <mailto:freedomyachts2003%
40yahoogroups.com>
yahoogroups.com
[mailto:freedomyachts2003@ <mailto:freedomyachts2003%
40yahoogroups.com>
laviolette
To: freedomyachts2003@ <mailto:freedomyachts2003%
40yahoogroups.com>
yahoogroups.com
matter if
alloy.
Healing
mast.
Frank Minelli myslo@ wrote:
Daniel,
at
Jersey.
Caribbean
since
delivered in Miami.
“daniel.oshaughnessy” daniel.oshaughnessy@ wrote:
Hi Freedom Folks!
info
Many Thanks
Dan
<http://us.rd.
yahoo.com/evt=43910/*http:/mobile.yahoo.com/mail>
on-the-go
<http://us.rd.
started.
<http://ca.answers. http://ca.answers.yahoo.com yahoo.com> Go
to Yahoo!
Answers.
As further evidence of the workability of our carbon fiber masts, at
the NE Boat Show, I asked a rigger about installing a leisure-furl
system on a Freedom. If you’re familiar with the system, it requires
a hole through the mast to attach the boom and associated furling
pieces. He said that it was no problem and they had done several with
no ill effects.
Lance
Bright Star
reasons. First
outside.
the boat
fiberglass
or so I
was told.
wishbones and
original owner
whole in
They put an
removable for
in the
masts. I spoke
especially on the forward face of the mast at this location. I have
seen no
this
up to
slightly over 40 knots) or on the inside of the mast. The bolts and
nuts
localized
be
quite a
to it.
Alan
daniel.oshaughnessy
Hi Allan,
outer
is
another story!)
Regards
Dan
40yahoogroups.com>
40yahoogroups.com>
yahoogroups.com
40yahoogroups.com>
laviolette
40yahoogroups.com>
yahoogroups.com
matter if
alloy.
Healing
mast.
Daniel,
at
Jersey.
since
delivered in Miami.
Hi Freedom Folks!
info
Many Thanks
Dan
<http://us.rd.
on-the-go
<http://us.rd.
started.
to Yahoo!
Answers.
Lance, Statement of a salesman =evidence??lance_ryley <lance_ryley@…> wrote: As further evidence of the workability of our carbon fiber masts, at the NE Boat Show, I asked a rigger about installing a leisure-furl system on a Freedom. If you’re familiar with the system, it requires a hole through the mast to attach the boom and associated furling pieces. He said that it was no problem and they had done several with no ill effects. Lance Bright Star
— In freedomyachts2003@yahoogroups.com, “Alan Kusinitz” <akusinitz@…> wrote: > > The reason I asked about the extent of the damage was for two reasons. First > is the possibility it is more extensive then you can see from the outside. > You can examine most of the mast from the inside when its out of the boat > with a good flashlight. The outer skin of the mast is gelcoat and fiberglass > cloth and is not really structural (only for compression purposes) or so I > was told. > > The second reason is that on my 33 the rig was converted from wishbones and > wraparound sails to straight booms and tracks. I am not the original owner > but was told this retrofit was done at Freedom. > > The gooseneck is through bolted to the mast. To do this they cut a whole
in > the front of each mast so they could insert and hold the bolts. They put an > aluminum plate over the hole (not structural) and its easily removable for > inspection or repair purposes. > > With so many people concerned about putting additional screw holes in the > mast I was surprised Freedom had put such large holes in the masts. I spoke > to several carbon fiber mast experts. The consensus was it was okay > especially on the forward face of the mast at this location. I have seen no > stress cracking or other signs of deterioration at the corners of this > opening (and the boat has been surfing over 10 knots and in winds up to > slightly over 40 knots) or on the inside of the mast. The bolts and nuts > holding the gooseneck also show not wear around them. > > So my conclusion is that the fear of some small holes or a small
localized > area of impact damage in similar locations is not an issue. > > > I did consider glassing the opening but was told that it would only be > cosmetic unless I beveled the underlying carbon fiber edges back quite a > ways. I felt that doing this might reduce strength rather then add to it. > > > > Alan > > F-33 Hull #51 1982 SEAPR > > > > _____ > > From: freedomyachts2003@yahoogroups.com > [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of daniel.oshaughnessy > Sent: Monday, March 12, 2007 5:50 AM > To: freedomyachts2003@yahoogroups.com > Subject: [freedomyachts2003] Re:
F33 Mast > > > > > Hi Allan, > > The damage is apparantly impact damage causing delamination ot the outer > shell and exposing some fibres. > > Don’t know how it occured as I bought the boat like this (but that is > another story!) > > Regards > > Dan > — In freedomyachts2003@ <mailto:freedomyachts2003% 40yahoogroups.com> > yahoogroups.com, “Alan Kusinitz” > <akusinitz@> wrote: > > > > How significant is the damage and how did it occur? > > > > Alan F-33 Hull # 51 1982 > > > > > > > > _____ > > > > From: freedomyachts2003@ <mailto:freedomyachts2003% 40yahoogroups.com> > yahoogroups.com > > [mailto:freedomyachts2003@ <mailto:freedomyachts2003%
40yahoogroups.com> > yahoogroups.com] On Behalf Of andre > laviolette > > Sent: Saturday, March 10, 2007 8:42 AM > > To: freedomyachts2003@ <mailto:freedomyachts2003% 40yahoogroups.com> > yahoogroups.com > > Subject: Re: [freedomyachts2003] F33 Mast > > > > > > > > Repair it ! Not difficult,epoxy and appropriate fibers. Does not > matter if > > becomes a little thicker. It still will be half the weight of alloy. > Healing > > moment and stability would be affected with much heavier alu. mast. > > > > Frank Minelli myslo@ wrote: > > > > > > > > Daniel, > > > > I own a F33 , 1981 also. (Hull No 32) Be advised that I found the > > thickness of the carbon fiber layup to be between 1/8 and 3/16 " at > >
deck level. (measured the stump of the broken stick) > > > > I replaced it with an aluminum pole, made by Pole Products of New > Jersey. > > That was in 1997. Been sailing thousands of miles in the Caribbean > since > > then, and that stick is doing fine. Cost at that time was $3500, > > delivered in Miami. > > > > “daniel.oshaughnessy” daniel.oshaughnessy@ wrote: > > > > > > Hi Freedom Folks! > > > > My 1981 Freedom 33 has some impact damage on the leading edge of the > > main mast; adjacent to the wishbone. > > > > I’m not too familiar with repairs to carbon masts. Any hints or info > > regarding suitable aluminum poles (wall thickness of ali mast for > > example) and perhaps a supplier in the Chesapeake bay area. > > > > Many Thanks > >
Dan > > > > > > > > > > > > > > > > _____ > > > > > > No need to miss a message. Get email > > <http://us.rd. > http://us.rd.yahoo.com/evt=43910/*http:/mobile.yahoo.com/mail > yahoo.com/evt=43910/*http:/mobile.yahoo.com/mail> > on-the-go > > with Yahoo! Mail for Mobile. Get > > <http://us.rd. > http://us.rd.yahoo.com/evt=43910/*http:/mobile.yahoo.com/mail > yahoo.com/evt=43910/*http:/mobile.yahoo.com/mail> > started. > > > > > > >
_____ > > > > Ask a question on any topic and get answers from real people. > > <http://ca.answers. http://ca.answers.yahoo.com yahoo.com> Go to Yahoo! > Answers. > > >
Get your own web address. Have a HUGE year through Yahoo! Small Business.
I wonder if they would put that in writing?
at
requires
with
no ill effects.
Lance
Bright Star
reasons. First
outside.
the boat
fiberglass
purposes)
or so I
was told.
wishbones and
original owner
a
whole in
They put an
removable for
holes
in the
masts. I spoke
okay
have
seen no
this
up to
nuts
localized
only
be
quite a
add
to it.
Alan
daniel.oshaughnessy
Hi Allan,
outer
that
is
another story!)
Regards
Dan
40yahoogroups.com>
40yahoogroups.com>
yahoogroups.com
40yahoogroups.com>
laviolette
40yahoogroups.com>
yahoogroups.com
matter if
alloy.
Healing
mast.
Daniel,
3/16 "
at
New
Jersey.
Caribbean
since
delivered in Miami.
Hi Freedom Folks!
of
info
for
Many Thanks
Dan
<http://us.rd.
on-the-go
<http://us.rd.
started.
to Yahoo!
Answers.
C’mon Dave, don’t be cynical! You KNOW (or BELIEVE) that carbon fibre
masts are good!
at
furl
requires
with
no ill effects.
Lance
Bright Star
reasons. First
outside.
of
the boat
fiberglass
purposes)
or so I
was told.
wishbones and
original owner
cut
a
whole in
They put an
removable for
holes
in the
masts. I spoke
okay
have
seen no
of
this
winds
up to
nuts
small
localized
only
be
back
quite a
add
to it.
Alan
daniel.oshaughnessy
Hi Allan,
outer
that
is
another story!)
Regards
Dan
40yahoogroups.com>
40yahoogroups.com>
yahoogroups.com
40yahoogroups.com>
laviolette
40yahoogroups.com>
yahoogroups.com
not
matter if
alloy.
Healing
mast.
Daniel,
3/16 "
at
New
Jersey.
Caribbean
since
$3500,
delivered in Miami.
Hi Freedom Folks!
of
or
info
for
Many Thanks
Dan
<http://us.rd.
on-the-go
<http://us.rd.
started.
Go
to Yahoo!
Answers.
Carbon fiber (as opposed to fibre) is great stuff but we know you
can’t just go drilling and cutting willy-nilly.
I was doing a Farallones Race one year and watched a SC 52 drop a CF
rig just ahead of us in mild conditions. That wasn’t the first or
last time that boat lost her rig. Apparently one or more of the
failures was due to improper instrument installation on the mast.
fibre
masts are good!
masts,
at
furl
requires
furling
several
with
no ill effects.
Lance
Bright Star
reasons. First
outside.
of
the boat
fiberglass
purposes)
or so I
was told.
wishbones and
original owner
cut
a
whole in
bolts.
They put an
removable for
holes
in the
masts. I spoke
was
okay
I
have
seen no
corners
of
this
winds
up to
bolts
nuts
small
localized
would
only
be
back
quite a
then
add
to it.
Alan
daniel.oshaughnessy
Hi Allan,
ot
outer
that
is
another story!)
Regards
Dan
40yahoogroups.com>
40yahoogroups.com>
yahoogroups.com
40yahoogroups.com>
laviolette
40yahoogroups.com>
yahoogroups.com
Does
not
matter if
of
alloy.
Healing
alu.
mast.
Daniel,
found
3/16 "
at
of
New
Jersey.
Caribbean
since
$3500,
delivered in Miami.
Hi Freedom Folks!
edge
of
hints
or
info
mast
for
Many Thanks
Dan
<http://us.rd.
on-the-go
<http://us.rd.
started.
people.
yahoo.com>
Go
to Yahoo!
Answers.
Statement of Kevin Montague, Northeast Rigging, 978-287-0060. If you
don’t know him, he’s an excellent rigger. Their loft is in the same
space as Composite Engineering (carbon fiber mast building, repair,
kayaks, etc.), and they have a lot of experience working with carbon
rigs, freestanding and otherwise. If you’re ever looking for a good
rigger in the Boston area, I can highly recommend his work.
— In freedomyachts2003@yahoogroups.com, Frank Minelli <myslo@…>
Lance,
requires
with
no ill effects.
Lance
Bright Star
reasons. First
outside.
the boat
fiberglass
purposes)
or so I
was told.
wishbones and
original owner
a
whole in
They put an
removable for
holes
in the
masts. I spoke
okay
have
seen no
of
this
winds
up to
nuts
localized
only
be
quite a
add
to it.
Alan
daniel.oshaughnessy
Hi Allan,
outer
that
is
another story!)
Regards
Dan
40yahoogroups.com>
40yahoogroups.com>
yahoogroups.com
40yahoogroups.com>
laviolette
40yahoogroups.com>
yahoogroups.com
not
matter if
alloy.
Healing
mast.
Daniel,
3/16 "
at
New
Jersey.
Caribbean
since
$3500,
delivered in Miami.
Hi Freedom Folks!
of
or
info
for
Many Thanks
Dan
<http://us.rd.
on-the-go
<http://us.rd.
started.
Go
to Yahoo!
Answers.
Posted by Dan OShaughnessy (daniel.oshaughnessy@…>)
Many Thanks to Allan and Michel, It is reasurring to hear that these masts can take such apparent abuse! If I were to install a “regular” boom, I would try to reach up from the base of the mast to couple backing washers and nuts. One could even make up some tool to hold the washers and screws whilst the external bolts were tightened. However, I still like the idea of the wishbones, so i’m not sure which way to go. I’ll have a good think when the mast is off. Regards Dan
Expecting? Get great news right away with email Auto-Check.Try the Yahoo! Mail Beta.
If you do choose to install a “regular” boom, you could do what Freedom did when the masts were built. Reinforce the area where the boom will be attached by wrapping it in fiberglass or carbon fiber and epoxy. Drill a 1.5" hole on the forward section of the mast at the height of the intended boom and use that hole to grip the nuts, bolts, etc, that will go on the inside of the mast to attach the gooseneck. Of course, check with a real expert first.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Dan OShaughnessySent: Wednesday, March 14, 2007 11:59 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: F33 Mast
Regards
Dan
IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter, and (ii) such taxpayers should seek advice based on the taxpayers’ particular circumstances from an independent tax advisor.
Dan,
Take a look at www.wyliecat.com to see the latest development in CF
freestanding masts combined with wishbones; it’s awesome! It
convinced me that there in fact is a future for wishbones. I’m
rerigging an F44 along the lines of the Wyliecat.
Best,
— In freedomyachts2003@yahoogroups.com, Dan OShaughnessy
abuse!
Regards
Dan
Dave, I wasn’t aware of the difference between fiber and fibre; I
thought it is just a difference between UK English and US English,
like centerboard and centreboard. So now I’m curious: what the heck
is fibre??
CF
fibre
masts are good!
masts,
at
furl
requires
furling
several
with
no ill effects.
Lance
Bright Star
two
reasons. First
from
outside.
out
of
the boat
gelcoat
fiberglass
purposes)
or so I
was told.
from
wishbones and
original owner
they
cut
a
whole in
bolts.
They put an
easily
removable for
screw
holes
in the
masts. I spoke
was
okay
location.
I
have
seen no
corners
of
this
winds
up to
bolts
nuts
small
localized
would
only
be
back
quite a
then
add
to it.
Alan
daniel.oshaughnessy
Hi Allan,
ot
outer
(but
that
is
another story!)
Regards
Dan
40yahoogroups.com>
40yahoogroups.com>
yahoogroups.com
40yahoogroups.com>
laviolette
40yahoogroups.com>
yahoogroups.com
Does
not
matter if
weight
of
alloy.
Healing
alu.
mast.
Daniel,
found
3/16 "
at
Products
of
New
Jersey.
Caribbean
since
$3500,
delivered in Miami.
Hi Freedom Folks!
edge
of
hints
or
info
mast
for
area.
Many Thanks
Dan
<http://us.rd.
on-the-go
<http://us.rd.
started.
people.
yahoo.com>
Go
to Yahoo!
Answers.
Posted by svfantasy@… (svfantasy@…>)
Michel,
I may have mentioned this before in this group, but here I go again. My 1981 Freedom 40 CK “Fantasy” (San Francisco Bay) has had this Wylie rig for years. It was installed by the previous owner, and I can attest to its ease of handling and sail trimming benefits. At one point after I first bought her, I too, considered installing standard booms. Many other sailors cringed and seemed put-off by the free-standing rig and wishbones. I’m certainly glad I regained my sanity and kept the wishbone rig. I remind other conventional rig sailors that airplanes got rid of wires decades ago!
The only drawback to me (but I’m lazy) is putting the sail covers on after a great day of sailing. Its a bit of work fitting the cover under each line of the sail catchment system.
By the way, my rig uses the Harken Batt-Car system on a track.
Jay
