Posted by williedoylemom (williedoylemom@…>)
We were talking with a F35 owner who said that he has had several
instances of being knocked about by the wakes of power boats and
then having his engine cut off in the middle of a busy boating
channel, the ICW, etc. This is certainly of great concern to us, as
new 35 owners. He supposes that it is becaue the F35 gas tank
(under the aft berth) is wide and not very deep. He feels that its
horizontal nature gives the gas a large surface on which to form
bubbles when sloshed and that these bubbles are then sucked in and
stop the flow of fuel. Sounds like a good explanation. But might it
be something else? If so, what?
Have any other 35 owners had this problem? If so, what did you do
to correct it? We are wondering about a smaller, connected tank
that might be of vertical design and would be fed by the larger,
main tank. The engine would then be fed from mid-tank level in the
small tank, say, and the smaller tank would be always kept fuel so
that bubbles on the top of it would not be sucked into the line.
This, of course, goes against the KISS principle and would,
therefore, but just one more thing to get messed up.
Any thoughts?
Thank you, Faith
