That would be my other comment about the deep draft vs wing keel, as
andre pointed out. On a 35’ boat, if you have shoal draft in new
england, there are a lot of places you can go that you can’t with a
deep keel. Try getting into cuttyhunk, or menemsha, with a deep draft
boat.
I agree that in most cases, the deep draft is going to give you
better upwind performance. I suspect it has as much to do with a
cleaner underwater shape as it does with ballast placement, etc, etc.
However, when I looked that the F-35 a few years back, it was pretty
clear that the difference in performance for an F-35 (which is not a
performance boat) between the two keels was negligble.
So it really comes down to what kind of sailing you’re going to do.
Are you going to turn this into a stripped down PHRF boat, race it
around the buoys, or are you going to cruise it? And where?
Bottom line, you’re going to end up with a great boat.
lance
— In freedomyachts2003@yahoogroups.com, andre laviolette
<andrelaviolette@…> wrote:
Deep keels do go better to winward, No question. Ballast is
another matter !
One of best to winward boats ever designed ( won SORC twice ten
years apart ) and that I was fortunate enough to be relief helmsman
was /is Robin Two Too. Ted Hoods one tonner. THREE Foot Draft. TEN
with the board down. Ballast ( stability ) and lift to windward are
two separate problems in the equation !
The experiments at C & C yachts demonstrated that same model
boat: shoal keel with centerboard and deep draught model, match
racing, that in going to windward there was less than 3 degrees
difference between them and that the board boat was marginaly faster
down wind, on average.
If you intend on cruisin Florida and the Bahamas ( East Coast for
that matter ) five feet of draught is the max you would wish for.
One, of the most popular cruising boats ever was/is the Morgan OI
41 , mostly for that 4’ 2" draught .
Thomas Hand <freesailah@…> wrote:
I own a deep keel F35. Great upwind performance. Also
have been sailing in up to 26 knots of wind this
summer and have not found a need to reef. I highly
recommend the deep keel.
regards
Gordon
— “michel.capel” <michel.capel@…> wrote:
Paul,
For once I disagree with Lance; The deeper the keel,
the better the
upwind performance because the pressure and the
holding power of the
water increase with the depth. On top of that, wave
action created by
wind (not current) works from the surface downwards.
At greater depths
there is less leeward movement of the water. Lastly,
a deeper keel
needs less ballast to create the same righting
moment.
If you can afford the draft in your favorite sailing
grounds, go for
the deepest keel.
Regards,
— In freedomyachts2003@yahoogroups.com, “ptecca63”
<petecca@>
I am considering buying the David Pedrick designed
Freedom 35 and am
trying to decide between the deep draft (whale
tail) keel and the
wing
keel. I would be very interested in hearing from
owners on their
experience with the boat’s performance upwind.
How much difference is there in the boat’s ability
to point? I know
the deep draft will be better. But how much
better? Are we talking
1
or 2 degrees, or more like 5 or 10 degrees?
Regards,
Paul
Do you Yahoo!?
Everyone is raving about the all-new Yahoo! Mail beta.
http://new.mail.yahoo.com
All new Yahoo! Mail -
Get a sneak peak at messages with a handy reading pane.
