Chuck, do you think the Watco was “natural”
or “golden oak”???
Douglas M. Payne
Tatum Partners
480-614-4915 Office
480-236-4561 Mobile
480-614-4916 Fax
doug.payne@…
TATUM PARTNERS
computers.
-----Original Message-----
[mailto:chuckkotler@…]
Sent: Monday, March 21, 2005 10:26
AM
To:
Finish for Ash " Ceiling" in Mull era Freedom’s
The wipe on Polly by Minwax or even by Homer Formby is
great. The orignal finish is Watco Danish Finishing Oil. That is
what the factory put on your boat originally. I used it on a 28 I had and
the results were great.
andre laviolette
<andrelaviolette@…> wrote:
Lionel,
I have had success by sanding
clean and bleaching, sometimes a srong peroxide bleach is also usefull.
The easiest finnish I have found, and I have tried most on the market is called
Wipe On Poly by Minwax, it penetrates leaves no steaks, rag it on!
Andre, “Scaramanga”.
lioneldmp7
<doug.payne@…> wrote:
I have repaired the deck leaks on my 87 Freedom 28
caused by two
months of torrentialrains here in Arizona. In the
V berth cabin, it
was the rear foot of the bow pulpit, where the bow
light wires enter
the cabin, and in the quarter berth area it was
the forward foot of
the stern pulpit where the stainles steel bolt screwed
from below up
into a threaded plate on the base of the pulpit
foot had striped out
allowing the seal on the toe rail to leak.
I would appreciate any advise on refinishing the
ash boards. I have
some black stains and discoloration and some areas
where the boards
have pulled away from the thin plywood backing
that is attached to
the hull. I can get those glued back in position
easily. Are these
boards stained and varnished, natural and
varnished, stained and
oiled??? I can’t tell from looking at the
finish.
I am considering bleach for the stains and sanding
the boards to get
rid of the finish, getting back to raw wood, then
refinish. Any
advise would be most appreciated. Thanks in
advance
Post
your free ad now! Yahoo! Canada Personals
Do you Yahoo!?
Yahoo! Small Business - Try
our new resources site!
