Yesterday, I mounted the new 1/2" wide tothed open flanked V-belt. It
fits perfect on top of the pulleys. No more screeching of the belt!
So I guess the problem is solved.
— In FreedomOwnersGroup@yahoogroups.com, “michel.capel”
<michel.capel@…> wrote:
Hi all,
My Perkins 4.108 with standard (? - not sure) Delco alternator has
a
very persistent slipping V-belt since I own the boat, that’s for
2,5
years now. I tightened the belt so much two weeks ago, that the
belt
flung to pieces after a short while. No matter what I do, it keeps
on
slipping. I have numerous replacement belts that I tried. However,
they are all XPZ belts (3/8" wide, 8 mm high, toothed, open
flanked)
and the belt sits deep in the pulleys. The pulleys are wide enough
to
take a 1/2" belt, so it seems. I roughed up the alternator pulley
with a file but this didn’t help.I finally took the time to study the problem in more depth, and
found
an interesting text on the site of Balmar:quote:
Balmar - Alternator Output Limits Based On Drive BeltsAnother key factor in determining the right alternator for your
system is the width of the belt driving the alternator. Typically,
most marine gas or diesel applications can be broken down into four
groups:Systems driven by a single v-belt measuring less than 1/2",
Systems driven by a single 1/2" v-belt,
Systems driven by dual or triple v-belts
Systems driven by multi-groove serpentine beltsV-Belts measuring less than 1/2" - Capable of driving alternators
up
to 80 amps (50A @ 24V)with horsepower demands up to three
horsepower.V-Belts measuring 1/2" - Capable of driving alternators up to 110
amps (65A @ 24V) with horsepower demands up to four horsepower.Multiple V-Belts - Capable of driving alternators up to 300 amps
(220A @ 24V) with horsepower demands up to 10 horsepower.Multi-Groove Serpentine Belt - Capable of driving alternators up to
300 amps (220A @ 24V) with horsepower demands up to 10 horsepower.Exceeding recommended output limits based on belt size will
ultimately lead to belt slippage and premature belt failure, and
potentially to resulting damage to the engine and alternator. DO
NOT
attempt to drive an alternator with an improperly-sized belt. In
addition to potential system damage, use of a high output
alternator
with an undersized belt could result in voiding of both engine and
alternator warranties. Don’t take the chance.High output alternators generate a substantially increased demand
on
drive belts over that created by standard OEM alternators. Balmar
strongly recommends the use of premium belts, such as “Top Cog” by
Dayco (http://www.daycoproducts.com) and “Green Stripe” by Gates
Rubber (http://www.gates.com) for maximal performance and belt life.Once installed, proper belt tensioning is essential for optimal
performance. When installing a new belt, run your engine for 15 to
30
minutes after initial tensioning. Re-tension after shutting down.
Repeat. Continue to inspect belt tension prior to engine start up
each time you use the boat. Tension whenever your belt deflection
exceeds engine manufacturer’s specifications.unquote
I mounted a new Delco alternator a few monthes ago and a battery
monitor. The Delco outputs as much as 75-80 amps, I found. I
thought
it was rated @ 55 amps max.Based on the Balmar info, my current 3/8" V-belt should - just -
do.
But I’m going to exchange it for an SPA belt (1/2" wide, 10 mm
deep,
covered walls (I hope more friction on the walles), no teeth) next
week and see what happens.I also found a serpentine conversion kit for the Perkins 4.108 from
TA Diesels at $575 ex shipping. Apparently, the belt slippage
problem
is so common on the 4.108, 4.107 and Westerbeke 40 that TAD makes
this conversion kit. I hope the heavier 1/2" V-belt will do the job
as it should with a standard alternator.Questions to you:
- Am I the only one with a persistently slipping 3/8" V-belt or am
I
the only one with a 3/8" belt?- What belts are you using on your 4.108s?
Best,
Michel Capel
F44 #4 Alabama Queen
