Don:
I don’t think so; that nut (really the head of a bolt) is what holds the unit together. If you only have the Fram and the engine-mounted filer, I think you need to open the bleed screw on the engine mounted filter and use the dinky little manual fuel pump lever to push the fuel through. To make life easier, make sure you fill the Fram with clean fuel before you reinstall it. Also, make sure that the perimeter O ring seats properly, or won’t won’t get an airtight seal.
Al
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of kollegewidgwockSent: Wednesday, April 26, 2006 12:31 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] Re: Fram primary filter element replacement-Thanks again Al. One final question (I hope). Is the single “nut on top” that you mentioned also the place to bleed the filter?Don-- In freedomyachts2003@yahoogroups.com, “Lorman, Alvin J.” <ajlorman@…> wrote:>> Don:> > The biggest problem in changing the Fram filter is that you have to> press up on the filter canister from below while you tighten the nut on> top. As there is a spring inside the filter, I always found that I had> one too few hands for the job. Then, last month I discovered the> problem. The Fram filters have a rubber gasket on top and bottom. When> replacing filters over the years, the bottom gaskets were falling off> and staying in the canister. I found it much easier to tighten when> there were no longer four old gaskets in the filters. > > Al> > -----Original Message-----> From: freedomyachts2003@yahoogroups.com> [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of kollegewidgwock> Sent: Wednesday, April 26, 2006 10:49 AM> To: freedomyachts2003@yahoogroups.com> Subject: [freedomyachts2003] Re: Fram primary filter element replacement> > > -Thanks Al,> I have appreciated all of the responses which suggested replacing > Fram w/ Racor but an especially grateful thanks to you for offering > advice on how to change the Fram element.> I will probably replace my primary filter eventually but, for now, I > needed helpful advice on making do with what I currently have.> Thanks again,> Don> > > > > > – In freedomyachts2003@yahoogroups.com, “Lorman, Alvin J.” > <ajlorman@> wrote:> >> > I have been through this on my F30. The Racor 500 series is > great, but> > I was unable to find any room in the engine “compartment” on my > boat to> > mount one. They are relatively long and require room underneath > for> > bleeding and filter changes.> > > > The original Fram filter is indeed listed as a gasoline filter. > Until I> > bought Ab Initio two years ago, it was the only filter on my boat > and> > presumably performed reasonably well. My solution was as > follows: I> > bought a Racor 215, which is a spin-on filter with a built-in > bleeding> > pump. It is relatively short and fit in the engine compartment > easily.> > I had originally intended to replace the Fram and then decided to> > install the Racor downstream of the Fram (there is enough room for> > this). The Fram is about a 30 micron filter, the Racor I use is 2> > microns (although you can get 10 and 30) and, of course, the engine> > filter is 2 microns. The Fram filter, which unscrews from the top > (the> > bottom nut is to drain the water), is not very sophisticated but > works.> > The pump on the Racor filters makes bleeding the engine relatively> > simple.> > > > The non-cartridge Racor filters are clearly less expensive than the> > cartridge filters, but I bought a lifetime supply of the cartridge> > filters on eBay for about $8 each. Similarly, I found a great > deal on> > the Fram filters on Amazon and bought them out at $4 a piece.> > > > I’d be happy to send you digital photos of my installation.> > > > Al Lorman> > F30 Ab Initio> > > > -----Original Message-----> > From: freedomyachts2003@yahoogroups.com> > [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of macks011> > Sent: Wednesday, April 26, 2006 8:59 AM> > To: freedomyachts2003@yahoogroups.com> > Subject: [freedomyachts2003] Re: Fram primary filter element > replacement> > > > > > I agree, dump the Fram and replace with Racor. I would go further. > I > > would go with Racor 500 drop ins, available all the time on ebay. > > The replacement cartriges are cheaper than spin ons and easier to > > change. I moved all my filtration out of the engine box to a more > > accessable location, installed 2 racor 500’s with a 30 micron in > > front of a 2 micron and a Walbro elec. pump to drive it. > Bleeding’s > > a breeze and I never have to change the stupid filter on the > Yanmar > > again. > > > > — In freedomyachts2003@yahoogroups.com, dave@ wrote:> > >> > > I’d dump the whole thing and get a Racor. Our 1987 28 had come > > with one of> > > these and looking in the catalogs it appeared to be a gas not a > > diesel> > > unit anyway. Get a basic spin-on Racor with a bowl and priming > > pump.> > > dge> > > > > > > I’m writing to ask if anyone can give me some advice on > > replacing and> > > > then bleeding the filter element on a Fram primary diesel fuel > > filter.> > > > I have a 1987 Freedom 30 (Solitude) and this filter looks like > it> > > > might be original. On the top, there is one hex head bolt > > (screw?)> > > > plus the fittings for fuel in and out. I’m not completely sure > > about> > > > the bottom but I seem to remember another hex head which might > > be the> > > > drain(?).> > > > If anyone is concerned that their response might not be > > appropriate> > > > for the whole Freedom group, I would be happy to receive an > > email at> > > > this address dlynch@> > > > Any and all advice/assistance is appreciated.> > > >> > > > Dr. Donald Lynch> > > > Associate Professor of Psychology> > > > Unity College-in-Maine> > > > dlynch@> > >> > > > > > > > > > > > > > _____ > > > > YAHOO! GROUPS LINKS > > > > > > > > * Visit your group "freedomyachts2003> > http://groups.yahoo.com/group/freedomyachts2003 " on the web.> > > > * To unsubscribe from this group, send an email to:> > freedomyachts2003-unsubscribe@yahoogroups.com> > <mailto:freedomyachts2003-unsubscribe@yahoogroups.com?> subject=Unsubscrib> > e> > > > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of> > Service http://docs.yahoo.com/info/terms/ . > > > > > > _____ > > > > > > > >
> > > > IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax > matters was neither written nor intended by the sender or Mayer, > Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer > for the purpose of avoiding tax penalties that may be imposed under > U.S. tax law. If any person uses or refers to any such tax advice in > promoting, marketing or recommending a partnership or other entity, > investment plan or arrangement to any taxpayer, then (i) the advice > was written to support the promotion or marketing (by a person other > than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter, > and (ii) such taxpayer should seek advice based on the taxpayers > particular circumstances from an independent tax advisor> > > >
> > > > This email and any files transmitted with it are intended solely > for the use of the individual or entity to whom they are addressed. > If you have received this email in error please notify the system > manager. If you are not the named addressee you should not > disseminate, distribute or copy this e-mail.> >> > > > > > > _____ > > YAHOO! GROUPS LINKS > > > > * Visit your group "freedomyachts2003>
http://groups.yahoo.com/group/freedomyachts2003 " on the web.> > * To unsubscribe from this group, send an email to:>
freedomyachts2003-unsubscribe@yahoogroups.com> <mailto:
freedomyachts2003-unsubscribe@yahoogroups.com?subject=Unsubscrib> e> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of> Service
http://docs.yahoo.com/info/terms/ . > > > _____ > > > >
> > IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisor> >
> > This email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.>IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe Maw LLP) of that transaction or matter, and (ii) such taxpayer should seek advice based on the taxpayers particular circumstances from an independent tax advisorThis email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
