Posted by Militello, Milo (milo.militello@…>)
Once again – as it relates to an F32,
NOT an F36 to which I have no knowledge of . . .
Is it a long sleeve, approximately 20’
ft long?
If so it attaches to the trapezoid opening
of the bow pulpit at each corner from under the pulpit and behind the aft
pulpit tubing.
It ruins along the deck adjacent the toe
rail on the port side with the end of the sleeve tied to the toe rail.
If your douser bag is not a 20’ ft
sleeve, please disregard everything I’ve told you and await a response
from an F36 owner.
Milo
[mailto:freedomyachts2003@yahoogroups.com] On
Behalf Of sew4you100
Sent: Monday, August 21, 2006 2:36
PM
To:
Freedom 36 Spinnaker
Thank you for your prompt reply, but where and how do
i fit the
douser bag ?— In freedomyachts2003@yahoogroups.com,
“Militello,
Milo” <milo.militello@…>
While I own a Hoyt F32 and I’m not sure of the spinnaker
differences
between the F36 and the F32, here’s some suggestions as it relates
to
the F32 gunmount spinnaker:
Do you have the retriever line attached to the grommet in the
center of
the sail? (there’s also a little white plastic ring at the middle
of
the foot tape that the retriever line should run through.
Make sure you’re running dead before the wind; square the yard;
release
the clew sheets, and while holding onto the halyard (and letting
it run
through your hand), pull the retriever line that should be running
through the launch sleeve and into the cockpit. If it’s not too
windy
and you get some practice, you can let go of the halyard instead of
letting it run through your hand, but don’t try it unless you’ve
had
several douses under your belt, so the chute doesn’t end up wrapped
around the bow.
It’s best to have a second pair of hands holding onto the halyard
until
you’re comfortable doing it singlehanded.
Raising the spinnaker is easier . . . pull the clews out to the
end of
the pole as best you can; make sure the retriever line is free to
run
through the launch sleeve; make sure you’re running before the
wind;
square the yard; hoist the spinnaker.
Please DON’T follow these suggestions if the F36 is different from
F32.
Milo
Island blues
On Behalf Of sew4you100
Sent: Monday, August 21, 2006 12:27 PM
Subject: [freedomyachts2003] Freedom 36 Spinnaker
We attempted to raise our spnnaker on the weekend but run into
problems getting it back into its douser bag. does anyone have
instructions for raising and retrieving, any photos would also be
helpful.
dave Corcoran
