Freedom-38 Vang Collar Slipping
Posted by jettebleu (jettebleu@…>)
My Vang collar slipped up my mast last week. Is this a common problem?
Is there a recommended solution?
Jettebleu
My Garhauer rigid vang has a rubber material between the mast and the stainless mast collar. It is simillar to inner tube rubber.
Andre " Scaramanga"jettebleu <jettebleu@…> wrote:
My Vang collar slipped up my mast last week. Is this a common problem?Is there a recommended solution?__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com
I installed a Garhauer rigid boom vang and it came without any sort of rubber sleeve. Thinking that some sort of sleeve would prevent slippage (since there’s a limit to how hard you can tighten it without risking crushing the mast), I used a hard rubber sleeve. The sleeve seems to have moved a bit in a year, but I’m not sure if that was due to insufficient tightening or the sleeve itself.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of andre lavioletteSent: Saturday, June 11, 2005 1:45 PMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] Freedom-38 Vang Collar Slipping
Jettebleu
__________________________________________________Do You Yahoo!?Tired of spam? Yahoo! Mail has the best spam protection around http://mail.yahoo.com This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
Posted by John Moran (sv_major_38@…>)
I installed a Hall Spar vang and collar set up with a ¼ or 3/8ths thick rubber gasket that is ribbed on one side in May 2002. Right after that my collar rotated about 10% to starboard while we were crossing the Gulf of Mexico from Ft. Myers to Key West during some very heavy weather. We noticed it in Key West. We retightened the collar with as much torque as I could apply by hand and it hasn’t moved since, though we haven’t been in a storm like that since either. My conclusion was, and is today that I just didn’t have it tight enough. I doubt you could crush the mast using ordinary hand tools.
Good luck!
John Mora
Al Lorman
F30 Ab Initio
Jettebleu
Discover Yahoo! Have fun online with music videos, cool games, IM more. Check it out!
Posted by markedwards55 (markedwards55@…>)
The issue of vang collar slippage just came up last week with a
Freedom 38 owner in CA. Even with the hard rubber material between
the mast and vang collar wall there can still be some movement in
this compression ring. What I suggested and what I have seen done
is to add stainless brackets from the port and starboard bolts that
compress the vang bracket around the mast to the aluminum mast
collar that is bolted to the deck. You might also lash the vang
collar on the centerline just under the vang axle down to the mast
collar. This two or three point approach should keep the vang
bracket from moving. Good luck, Mark Edwards, Freedom Yachts
sort of
slippage
risking
to
Al Lorman
F30 Ab Initio
laviolette
Jettebleu
Andre " Scaramanga"
problem?
Do You Yahoo!?
Yahoo! Groups Links
In case its of interest on my Freedom 33 the vang was attached to a custom bracket that bolted onto the mast collar with two of the mast collar bolts that go through the cabin top. The tab on the collar that sticks out facing aft looks like it was ground off so as not to interfere. Thus there was no contact with the mast at all. This year had a new custom brackets made that attach in a similar way but support boomkickers as well as vangs. This arrangement works very well has great clearance over the dodger for the mizzen and over the bow pulpit for the main and puts less stress on the attachment points then a fully rigid vang.
Alan F-33 Hull #51 SEAPR
Sent: Thursday, June 16, 2005 1:09 PM
Subject: [freedomyachts2003] Re: Freedom-38 Vang Collar Slipping
The issue of vang collar slippage just came up last week with a Freedom 38 owner in CA. Even with the hard rubber material between the mast and vang collar wall there can still be some movement in this compression ring. What I suggested and what I have seen done is to add stainless brackets from the port and starboard bolts that compress the vang bracket around the mast to the aluminum mast collar that is bolted to the deck. You might also lash the vang collar on the centerline just under the vang axle down to the mast collar. This two or three point approach should keep the vang bracket from moving. Good luck, Mark Edwards, Freedom Yachts— In freedomyachts2003@yahoogroups.com, “Lorman, Alvin J.” <ajlorman@y…> wrote:> I installed a Garhauer rigid boom vang and it came without any sort of> rubber sleeve. Thinking that some sort of sleeve would prevent slippage> (since there’s a limit to how hard you can tighten it without risking> crushing the mast), I used a hard rubber sleeve. The sleeve seems to> have moved a bit in a year, but I’m not sure if that was due to> insufficient tightening or the sleeve itself.> > Al Lorman> F30 Ab Initio> > -----Original Message-----> From: freedomyachts2003@yahoogroups.com> [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of andre laviolette> Sent: Saturday, June 11, 2005 1:45 PM> To: freedomyachts2003@yahoogroups.com> Subject: Re: [freedomyachts2003] Freedom-38 Vang Collar Slipping> > > Jettebleu> > My Garhauer rigid vang has a rubber material between the mast and the> stainless mast collar. It is simillar to inner tube rubber.> > Andre " Scaramanga"> > jettebleu <jettebleu@y…> wrote:> > My Vang collar slipped up my mast last week. Is this a common> problem?> Is there a recommended solution?> > > > > > __________________________________________________> Do You Yahoo!?> Tired of spam? Yahoo! Mail has the best spam protection around > http://mail.yahoo.com > > _____ > > Yahoo! Groups Links> > > * To visit your group on the web, go to:> http://groups.yahoo.com/group/freedomyachts2003/> > * To unsubscribe from this group, send an email to:> freedomyachts2003-unsubscribe@yahoogroups.com> <mailto:freedomyachts2003-unsubscribe@yahoogroups.com?subject=Unsubscrib> e> > > * Your use of Yahoo! Groups is subject to the Yahoo! Terms of> Service http://docs.yahoo.com/info/terms/ . > > > This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
