The Freedom 45 is a very nice boat. It has some features that I think
are very well thought out, including having the water and fuel tanks on
centerline right over the keel. The engine room has excellent access,
as do most of the steering components. The original design of the
companionway slider was a two-piece system that was notorious for
leaking; many owners have converted it to a one-piece slide.
The fit and finish below is very good, with cherry used extensively
instead of teak to keep the interior light and airy. There is a ton of
storage throughout the boat, and more can be added with a little
ingenuity. The master cabin has an inline queen-sized bed, with a 3/4
walkaround that makes it easy to get in and out without having to climb
over your partner. There are two heads. The forward is accessible from
the salon or from the v-berth. The aft head has a separate shower stall.
The rig is a typical Freedom sloop, with a small headsail on a
camberspar (if it’s the original setup) and a very large main with a
lot of roach. The 45 came in two sized rigs; a tall and
an ‘intracoastal’ rig. I believe the mast height on the tall is about
63’, so it still handles the intracoastal while providing a bit more
sail area than its shorter cousin. I have seen at least one 45 that
was converted from camber spar to roller furling, and further one with
a roller furling 100% jib on a hoyt jib-boom. an electric 2-speed winch
(standard) helps alleviate the issues around hauling up such a massive
sail.
I wasn’t sure I would like the feel of sailing a center-cockpit boat,
but the 45 is a joy, feels stable, tracks well and is responsive. I
don’t have a lot of upwind experience (yet), but we were pretty happy
with 35 - 40 degrees true. In moderate air, we saw about 5.5 kts upwind
and 8.5 downwind (with gennaker). I’ve been told it’s not a light-air
boat (at 30,000lbs I’m not surprised), but I think it probably performs
better than many other 45s in that regard.
there may have been some 45s that had some production issues, mostly
centering around the bedding of ports. For some reason, it seems
Freedom never did quite get that right, or at least consistent, across
a wide number of models.
While I’m going to miss the cat-ketch rig and its versatility, I think
the compromise of the 45, still with a relatively shallow draft and
more waterline for passagemaking, is well worth it and I think she’s a
great vessel.
The only concern I have at this point is the main sheet, which runs
from a traveler behind the wheel, along the boom, and then back to the
cockpit into a line stopper. The jib sheets similarly, meaning that you
have to leave the helm to adjust either sail (or have a second set of
hands). On the plus side, the helmsperson does have control of the
traveler, so a quick dump of the main if overpowered is possible.
Just my 2cts, but I think if you find one at a price you like, you
could do worse but you’d be hard pressed to do better.
Unless, of course, you want a cat-ketch. I’ll extoll its virtues to you
for as long as you can stand it, and then I’ll sell you mine
Lance
Bright Star / Glory
— In FreedomOwnersGroup@yahoogroups.com, “nathansteve”
<Nathansteve@…> wrote:
We are interested in possibly buying a Feedom 45. We would love to
connect with other 45 owners to learn about their experiences with
this
boat. ALso any susggestions on finding one for sale would also be
helpfull.
