Freshwater Pump (was Water Tank Freedom 32)
Posted by Thomas Carlton (Finesse@…>)
I have the reverse problem. Much of the FW system was disconnected for refit. We
did not go near the pump, which is very hard to get to. After reconnecting
things, the FW pump cycled once, then quit. any advice?
Thomas
F-33 L’Audace
— <crwindy@…> wrote:
Date: Fri, 17 Jun 2005 18:26:33 -0400
Subject: Re: [freedomyachts2003] Water Tank Freedom 32
On mine the pump would continue until it blew the circuit breaker. This was due to a bad pressure switch as well.
Alan F-33 Hull 51 SEAPR
Sent: Friday, June 17, 2005 11:26 PM
Subject: [freedomyachts2003] Freshwater Pump (was Water Tank Freedom 32)
I have the reverse problem. Much of the FW system was disconnected for refit. We did not go near the pump, which is very hard to get to. After reconnecting things, the FW pump cycled once, then quit. any advice?ThomasF-33 L’Audace— <crwindy@…> wrote:From: <crwindy@…>Date: Fri, 17 Jun 2005 18:26:33 -0400To: <freedomyachts2003@yahoogroups.com>Subject: Re: [freedomyachts2003] Water Tank Freedom 32
advice?
Happens on my boat too on rare occasions without even doing anything
to the freshwater system.
Nine times out of ten I can reach around under there and jiggle the
wires to locate a loose connection.
In your situation I would check the following, in this order:
Meter the breaker on your panel that serves the pump
Check the breaker on your panel, make certain that it’s not tripped
Check/meter the inline fuse, make sure that it isn’t blown
Meter the wiring on both sides of the pressure switch (that will tell you if it is still opnl)
If none of these things enlighten you, it probably means your gonna have to pull the pump.
Yahoo! Sports Rekindle the Rivalries. Sign up for Fantasy Football
