What is wrong with the sink?
I learned that the galley faucet and drains on the Hoyt 32 were from Central Brass, which still makes them and they seem to have worn well. Not so the galley sink, for which i can’t find a replacement. Any clues, anyone?Jack “Lorman, Alvin J.” <ajlorman@yahoo.com> wrote: Paul: I’m not 100 percent sure, but I’ve always thought that the faucet was a standard residential faucet. The set-up with one large hole in the counter for supply lines is very
common on residential faucets. I think you’ll find that most residential units fit. Best, Al Lorman F30 Ab Initio -----Original Message-----From: freedomyachts2003@yahoogroups.com
[mailto:freedomyachts2003@yahoogroups.com] On Behalf Of svbagatelleSent: Saturday, May 12, 2007 5:23 PMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] galley sink faucet on F30 Has anybody replaced their faucet? Mine is made by Indiana Brass and it leaks despite replacing o-rings. I am not sure if it is a marine faucet, it seems to be more similar to the standard kitchen faucets than the ones I see advertised in marine stores. The main thing I think I need to match is to have the hot and cold supplies feed through one one large hole in the galley counter, and there are two set
screws on either side. The footprint of the faucet is about 2"x8".Paul"Bagatelle" IRS CIRCULAR 230 NOTICE. Any advice expressed above as to tax matters was neither written nor intended by the sender or Mayer, Brown, Rowe & Maw LLP to be used and cannot be used by any taxpayer for the purpose of avoiding tax penalties that may be imposed under U.S. tax law. If any person uses or refers to any such tax advice in promoting, marketing or recommending a partnership or other entity, investment plan or arrangement to any taxpayer, then (i) the advice was written to support the promotion or marketing (by a person other than Mayer, Brown, Rowe & Maw LLP) of that transaction or matter, and (ii) such taxpayers should seek advice based on the taxpayers particular circumstances from an
independent tax advisor. This email and any files transmitted with it are intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error please notify the system manager. If you are not the named addressee you should not disseminate, distribute or copy this e-mail.
