I spoke with the Spartite people a few
years ago before doing my main and mizzen. They didn’t mention having two
types and I only saw one to order.
In my case I put Vaseline to prevent the
spartite from sticking to the aluminum collar but did let it adhere to the mast
since I couldn’t think of any reason not to. Its worked very well.
My only advise other then sealing below it
very well before pouring is to not overmix and to work quickly since it can set
up very fast in the can or bucket and then you waste a lot.
Alan F-33 Hull # 51 1982 SEAPR
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of tom
Sent: Tuesday, September 12, 2006
2:10 PM
Hardness of Spartite
Hello Michel,
I used Spartite on my mizzen in place of the original collar in 1999.
A year later, I did the same for the main. I’ve had no problems ever
since. I haven’t removed the masts since then, but I followed
instructions and put Vaseline on the masts so the Spartite wouldn’t stick.
At the time I installed it, Spartite had two grades. They recomended
the “racing” grade for unstayed masts. I don’t know if they still
have two grades, but if they do, the racing grade is harder than the
regular.
Tom Marlow
Ketch 22
— In freedomyachts2003@yahoogroups.com,
“michel.capel”
<michel.capel@…> wrote:
All,
I need to make new rubber or PU mast collars for Alabama Queen (F44).
I can use Spartite but also other two part hardness PU-rubbers.
Spartite is 55-60 Shore hardness, some say even too soft for
conventionally rigged masts.
I fear that it is far too soft for our freestanding poles; I’m
thinking of shore 80 or 90 hardness instead.
How is your experience with Spartite?
thanks for your opinions.
