headliner adhesive
Posted by rocclear (aronella@…>)
I recently rebedded leaking port lights on my Freedom 35. The plywood
panels had rotted, and are being replaced. What adhesive can I use to
reattatch the vinyl material to the 1/8" wood?
thanks,
Lou Spitz
F35 # 23
Are you sure you really want to re-use the plywood and vinyl? The foam
backing is probably crumbled away or going to be soon. If you glue the
vinyl to plywood without foam backing, it will be very hard to get a
smooth surface. I threw everything out and replaced plywood and vinyl
with sheets of 4 mm foamed PVC. Does not rot, bends like plywood, not
expensive, soft matte finish. If you want to keep the plywood/vinyl
situation anyway, I would use a sprayable contact glue suitable for
foam. Upholsterers (cars and furniture) use it.
Good luck,
— In FreedomOwnersGroup@yahoogroups.com, “rocclear” <aronella@…>
plywood
to
thanks,
Lou Spitz
F35 # 23
So you just used the foamed PVC as the
total replacement, no vinyl cover etc.? Since its only 8’ long where did
you butt up the halves in the middle?
Bob
FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of michel.capel
Sent: Wednesday, June 20, 2007
3:31 AM
To:
Subject: [FreedomOwnersGroup] Re:
headliner adhesive
vinyl? The foam
Good luck,
plywood
to
thanks,
Lou Spitz
F35 # 23
Posted by louis spitz (aronella@…>)
Thanks for the tip, Michael. I will try the adhesive to vinyl for this season, or until I need more. Then I will investigate the foam PVC.
Where did you get it?
Lou
Sent: Wednesday, June 20, 2007 6:51 AM
Subject: RE: [FreedomOwnersGroup] Re: headliner adhesive
So you just used the foamed PVC as the total replacement, no vinyl cover etc.? Since its only 8’ long where did you butt up the halves in the middle?
Bob
From: FreedomOwnersGroup@yahoogroups.com [mailto:FreedomOwnersGroup@yahoogroups.com] On Behalf Of michel.capelSent: Wednesday, June 20, 2007 3:31 AMTo: FreedomOwnersGroup@yahoogroups.comSubject: [FreedomOwnersGroup] Re: headliner adhesive
Are you sure you really want to re-use the plywood and vinyl? The foam backing is probably crumbled away or going to be soon. If you glue the vinyl to plywood without foam backing, it will be very hard to get a smooth surface. I threw everything out and replaced plywood and vinyl with sheets of 4 mm foamed PVC. Does not rot, bends like plywood, not expensive, soft matte finish. If you want to keep the plywood/vinyl situation anyway, I would use a sprayable contact glue suitable for foam. Upholsterers (cars and furniture) use it.Good luck, Michel— In FreedomOwnersGroup@yahoogroups.com, “rocclear” <aronella@…> wrote:>> I recently rebedded leaking port lights on my Freedom 35. The plywood > panels had rotted, and are being replaced. What adhesive can I use to > reattatch the vinyl material to the 1/8" wood?> thanks,> Lou Spitz> F35 # 23>
Posted by John Carles (johncarles@…>)
Where did you buy the PVC?Thanks"michel.capel" <michel.capel@…> wrote: Are you sure you really want to re-use the plywood and vinyl? The foam backing is probably crumbled away or going to be soon. If you glue the vinyl to plywood without foam backing, it will be very hard to get a smooth surface. I threw everything out and replaced plywood and vinyl with sheets of 4 mm foamed PVC. Does not rot, bends like plywood, not expensive, soft matte finish. If you want to keep the plywood/vinyl
situation anyway, I would use a sprayable contact glue suitable for foam. Upholsterers (cars and furniture) use it. Good luck, Michel — In FreedomOwnersGroup@yahoogroups.com, “rocclear” <aronella@…> wrote: > > I recently rebedded leaking port lights on my Freedom 35. The plywood > panels had rotted, and are being replaced. What adhesive can I use to > reattatch the vinyl material to the 1/8" wood? > thanks, > Lou Spitz > F35 # 23 >
The surface of the foamed PVC looks very good; needs no further
covering, unless you want the soft feel of the vinyl. The sheets are
3 meters x 2 meters, so there are no butts. Just the teak battens
that were there already. I varnished them first.
— In FreedomOwnersGroup@yahoogroups.com, “Bob Weeks”
cover
middle?
Bob
michel.capel
foam
a
vinyl
not
plywood/vinyl
for
Good luck,
— In FreedomOwnersGroup@ <mailto:FreedomOwnersGroup%
40yahoogroups.com>
yahoogroups.com, “rocclear” <aronella@>
plywood
use
to
thanks,
Lou Spitz
F35 # 23
Foamed PVC is used is the printing business to print large
billboards on. The thicker sizes are used in boatbuilding as a core
material in stead of balsa. It’s also used for interior building,
trade show stands and displays etc. A brandname used in the UK is
Palight. I don’t know an US brandname, but you should be able to
find it.
— In FreedomOwnersGroup@yahoogroups.com, louis spitz
PVC.
Lou
Bob
The foam
glue the
get a
vinyl
plywood, not
plywood/vinyl
for
Good luck,
<aronella@>
plywood
use
to
thanks,
Lou Spitz
F35 # 23
Dumb question:
Does this stuff float?? (proably). Could one cut this to shape to replace the
floor of an inflatable boat if you get a thich enough piece?? Have inflatable
floor that leaks. I already replaced it, but looking for alternatives for next
time.
craig
find it.
PVC.
Lou
Bob
The foam
glue the
get a
vinyl
plywood, not
plywood/vinyl
for
Good luck,
<aronella@>
plywood
use
to
thanks,
Lou Spitz
F35 # 23
Posted by barbara.wall (Joseph.Wall@…>)
— In FreedomOwnersGroup@yahoogroups.com, <crwindy@…> wrote:
A brand name for this material in the USA is Sintra. I just bought
three 4’x8’ sheets for $42 a piece.
Dumb question:
replace the floor of an inflatable boat if you get a thich enough
piece?? Have inflatable floor that leaks. I already replaced it, but
looking for alternatives for next time.
craig
core
find it.
for
foam
PVC.
Lou
Bob
michel.capel
The foam
glue the
to
get a
vinyl
plywood, not
plywood/vinyl
suitable
for
Good luck,
<aronella@>
The
plywood
can I
use
to
thanks,
Lou Spitz
F35 # 23
Posted by Weaver Roger (rogerweav@…>)
Barb, Would be kind enough to share were you purchase this Sintra product.
Maybe Home Depot or Lowe’s?
Roger
________________________________________________________________________________\
Don’t get soaked. Take a quick peak at the forecast
with the Yahoo! Search weather shortcut.
http://tools.search.yahoo.com/shortcuts/#loc_weather
Roger,
Sure can for whatever help it may be. I bought the Sintra at a
commercial Graphics Arts supply shop. They took three days to obtain
what I wanted from their distributor. Don’t think a retail outlet
such as Lowe’s or Home Depot would be likely to carry such a
specialty item.
Joe Wall
— In FreedomOwnersGroup@yahoogroups.com, Weaver Roger
product.
Roger
Looking for a deal? Find great prices on flights and hotels with Yahoo!
FareChase.
http://farechase.yahoo.com/
