George have looked up your links on this subject and it looks
impressive but doesnt really give any information can you expand on
the parts used to build the watermaker and refrigeration.
What pump is used where sourced same with the RO vessel and what
membrane was used also the same information on refrigeration side.I am
sure other members would like to have a go at
this type of project.
I have just had a watermaker installed in my F32 from Quality Water Works. I found the product on EBay. It is new-from a “seller” at the bottom of the page. It was very inexpensive comparatively. It is 10 GPH for about $2500.00. It is very impressive looking!!! Don’t know how it works yet. The seller was very helpful and a great guy. He provided step by step instructions for installation. I could not have installed it myself as I had thought about doing. It has many components so the parts can be installed where ever there is room. I can’t try it in the Chesapeake-the water is tooooo nasty. Hopefully during the winter when I hopefully will be in the Bahama’s I can report back to you.
SWARD— On Fri, 10/10/08, davisjonathan1946 <jonannie@…> wrote:
From: davisjonathan1946 <jonannie@…>Subject: [FreedomOwnersGroup] Home built Water maker(Frankenmaker)To: FreedomOwnersGroup@yahoogroups.comDate: Friday, October 10, 2008, 8:32 AM
George have looked up your links on this subject and it looks impressive but doesnt really give any information can you expand on the parts used to build the watermaker and refrigeration.What pump is used where sourced same with the RO vessel and what membrane was used also the same information on refrigeration side.I am sure other members would like to have a go at this type of project.
