The locals say that I don’t need a crane to launch my Freedom 25. According to
them, the
launch ramp is steep enough to back the cradle trailer down and let the boat
float off. Has
anyone ever launched a fixed keel boat like an F25 like this before? Should I
try it?
I wouldn’t; you’ll be able to do it once, but getting the trailer back might be another story; maybe the ‘locals’ just want a good show…
-----Original Message-----
Sent: Fri, 18 May 2007 10:14 AM
Subject: [freedomyachts2003] launching F25 with cradle trailer on ramp?
The locals say that I don’t need a crane to launch my Freedom 25. According to them, the
launch ramp is steep enough to back the cradle trailer down and let the boat float off. Has
anyone ever launched a fixed keel boat like an F25 like this before? Should I try it?
AOL now offers free email to everyone. Find out more about what’s free from AOL at AOL.com.
be another
them,
float off.
Has
try it?
AOL at AOL.com.
J-24s usually launch from a crane, and they weigh 100 lbs. less, and
draw about 6" less than the F-25 Herm
Should I try it?
That’s 1000 lbs. less.
Should I try it?
A keel boat under about 30 feet can be
launched and retrieved with a “launch strap” arrangement. A 5/8 to ¾
inch line or suitable strap with enough capacity to handle the weight of the
trailer or boat. We launched our Columbia
22 in this manner which has a deep fin keel. You block the wheels of the
trailer at waters edge, detach the trailer from the tow vehicle, connect about
a 50 foot line to trailer and truck, pull the slack out, pull the chocks, and
back the trailer as deep as it needs to go to float off the boat. No big deal. The
boat can be retrieved in the same manner. I have launched my Mull
28 that way a couple times and I have seen 30 footers done that way.
float off. Has
try it?
show…
ramp?
__
Thanks for the input. I splashed her in today. With a crane. I decided it was
the only safe
way to step the mast. Everything went ok. Although they were a bit flummoxed by
the lack
of stays when lifting the mast. Question: We just set the mast down through the
tube and
onto the spindle. But there’s a slight amount of play at the partners. Is this
normal. Also,
what keeps the mast on the spindle? It’s own weight?
Should I try it?
About the slight play at the partners: Did you accidentally omit the
Teflon bearing (1/16" thick) that resides in the shallow groove at
the top of the mast tube and bears against the stainless steel collar
on the mast at the partners? This Teflon bearing is the width of the
shallow, about 1-1/2" groove near the top of the mast-enclosing tube.
The mast will stay on the spindle because of its weight, AND all
those halyards and reefing lines that reeve through blocks at the
deck near the mast. Herm
At 08:29 PM 5/21/2007, fgljff wrote:
Guys,
decided it was the only safe
flummoxed by the lack
through the tube and
partners. Is this normal. Also,
Should I try it?
That’s what that was. A flat plastic ring broke as we were inserting the mast
through the
partners. I pulled it out. What can be done about that? Any way to put another
one in
without unstepping the mast?
Guys,
Should I try it?
I don’t think you can properly access this without withdrawing the
mast some considerable way. BTW: if you yank the mast again, consider
using a 6" Fernco fitting as your mast boot/flashing. These are
available at plumbing supply stores. You want the one that’s intended
to mate 6" copper/plastic to 6" clay pipe. It’s a bell shape ideal
for the F-25 mast. Herm
the mast through the
put another one in
Guys,
Should I try it?
I don’t think it’s in the cards to withdraw the mast again this season. Can I
sail the boat
anyway without that teflon strip? Otherwise, is there a way to address the
problem
temporarily?
put another one in
Guys,
before?
Should I try it?
