lazy jacks on Freedom 35- reconfigure?
Posted by rocclear (aronella@…>)
Did anyone change the lazy jack system to make it detachable?
Does the boom need the support of the lazy-jacks when the sail is
lowered?
It’s a real pain to put the sail cover on, with the lazy jack ‘cut-
outs’.
I was also thinking of the ‘mack-pack’ or ‘stack pack’ system.
Thoughts and experiences most needed and welcome.
Lou
F35 ‘Ripple Effect’ #23
Posted by fredmolden@…> (fredmolden@…>)
Hello Lou,
I have just had the North Sails version of a stack pack installed on my F35.
Works great. Lazy jack system is modified a bit and bolt rope on main foot
is removed but essentially the same as before. Just drop the main and zip
it up. I also do not need to tighten the reef lines when dropping the sail
so raising the main is easier.
I use the rigid vang to support the boom. In fact I adjusted it to remove
the boom load on the main so I could get better shape in light winds.
Fred
-----Original Message-----
[mailto:freedomyachts2003@yahoogroups.com] On Behalf Of rocclear
Sent: Monday, June 04, 2007 10:32 AM
Subject: [freedomyachts2003] lazy jacks on Freedom 35- reconfigure?
lowered?
outs’.
Lou
Yahoo! Groups Links
Lou, I am real happy with the Doyle Stack Pack. It has a membrane that some others do not that keeps the cover flat against the sail when up. The white cover lasted 5 years in the so Fla sun. It was white. A darker sunbella would last longer. Not cheap, the replacement cover only was 76 $ a foot.New instalation was more. Lazy jacks could hold the boom up but would need constant adjustements. I have a solid Garhauer vang. A great peice of equipment. Andre, " Scaramanga "rocclear <aronella@…> wrote: Did anyone change the lazy jack system to make it detachable?Does the boom need the support of the lazy-jacks when the sail is lowered?It’s a real pain to put the sail cover on, with the lazy jack ‘cut-outs’.I was also thinking of the ‘mack-pack’ or ‘stack pack’ system.Thoughts and experiences most needed and welcome.Thanks,LouF35 ‘Ripple Effect’ #23
Ask a question on any topic and get answers from real people. Go to Yahoo! Answers.
Hi Lou,
One way to relieve pressure on the lazy jacks to to use your main
halyard as a topping life to hold up the boom after you have dropped the
sail. Putting the sailcover on with slack lazyjacks is much
easier. You’ll need to have something to hold up the boom. Either a rigid
vang, lazyjacks or a topping lift. The main halyard as topping lift is the
least expensive and it works for me.
Good luck.
TW F32 Anoush Koon
Pemaquid, ME
lowered?
outs’.
Lou
Checked by AVG Free Edition.
Version: 7.5.472 / Virus Database: 269.8.7/830 - Release Date: 6/3/2007
12:47 PM
Attachment: (application/octet-stream) 4fcc0f0.jpg [not stored]
Attachment: (application/octet-stream) 4fcc1ca.jpg [not stored]
Attachment: None [not stored]
Version: 7.5.472 / Virus Database: 269.8.7/830 - Release Date: 6/3/2007 12:47 PM
Posted by Jay T. Reed (reedjayt@…>)
Lou
When my wife and I bought our 35 three years ago, we had problems with the
top batten getting caught in the lazy jacks. I replaced the line on the
lazy jacks and made it long enough to loosen before I raised the main. This
made it much easier to raise the main, but the boom did sag down
significantly. This year I did a lot of work on the mast and boom,
including painting both. As a part of this project I replaced the spring in
the boomvang and put in a heaver spring. I also had all the bearings
replaced in the bat-cars. Since I needed to replace the main sail cover
anyway and since I hated wrestling with it, I decided to get the stackpack.
Saturday morning was our first opportunity to try the new stackpack. We
almost decided to hold off, since the wind was 15 to 18 knots. I decided we
would at least try to raise the main to see if there was a problem, since we
now have 4 sets of lazy jack lines instead of 2. My wife put the boat into
the wind. I threw one wrap of the main sheet around the winch and raised
the main by hand until the second batten cleared the lazy jack lines. Once
they were clear, I used the power winch to raise the main the rest of the
way. It went up so easily that we decided to have some fun sailing.
Dropping the main was great, since we no longer need to worry about sail
ties or reefing lines that fall down in the cockpit. When I got into the
dock, all I needed to do was zip up the stackpack.
If you are going with a stackpack I would make sure the boomvang supports
the boom for the most part. Mine still sags about an inch, but that seems
to be fine. Before I replaced the spring it would sag to the dodger. Mark
Edwards suggested raising the main by hand until the battens were clear. I
was unable to do that before I replaced the bearings in the bat cars.
Harken doesn’t recommend using lubrication, since the bearings can slide and
create a flat spot. That’s what had occurred with mine. I don’t know about
the mack-pack, but I expect the same issues would apply to both.
Hope this helps
Jay
Reply-To: freedomyachts2003@yahoogroups.com
Date: Mon, 04 Jun 2007 14:31:40 -0000
lowered?
outs’.
Lou
Like puzzles? Play free games & earn great prizes. Play Clink now.
http://club.live.com/clink.aspx?icid=clink_hotmailtextlink2
If you don’t have a rigid vang, the lazy jacks are what hold up the boom. I have a rigid vang and so usually have little tension on the lazy jacks, thus making it much easier to put the sail cover on.
Al Lorman
F30 Ab Initio
-----Original Message-----From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of rocclearSent: Monday, June 04, 2007 10:32 AMTo: freedomyachts2003@yahoogroups.comSubject: [freedomyachts2003] lazy jacks on Freedom 35- reconfigure?
Posted by willie doyle (williedoylemom@…>)
Hi Lou, I would echo everything about vang and topping left that the others have said. We fasten the main halyard to the end of the boom and tighten it up. This keeps a load off the van and keeps the main from swinging across the dodger causing wear. We LOVE our Mackpack. Makes bringing down the sail so easy. My husband does need to go topside to help it into the sailcover but we leave zipping up for after docking. We’ve taken out the second reef point - less line to deal with. We cannot recommend the stackpack idea highly enough. Faith www.faithandrewsbedford.comThomas Wales <twales@…> wrote: Hi Lou,One way to relieve pressure on the lazy jacks to to use your main halyard as a topping life to hold up the boom after you have dropped the
sail. Putting the sailcover on with slack lazyjacks is much easier. You’ll need to have something to hold up the boom. Either a rigid vang, lazyjacks or a topping lift. The main halyard as topping lift is the least expensive and it works for me.Good luck.TW F32 Anoush KoonPemaquid, MEAt 02:31 PM 6/4/2007 +0000, you wrote:>Did anyone change the lazy jack system to make it detachable?>Does the boom need the support of the lazy-jacks when the sail is>lowered?>It’s a real pain to put the sail cover on, with the lazy jack ‘cut->outs’.>I was also thinking of the ‘mack-pack’ or ‘stack pack’ system.>Thoughts and experiences most needed and welcome.>Thanks,>Lou>F35 ‘Ripple Effect’ #23>>>>No virus found in this incoming message.>Checked by AVG Free Edition.>Version: 7.5.472 / Virus Database: 269.8.7/830 - Release Date:
6/3/2007 >12:47 PMNo virus found in this outgoing message.Checked by AVG Free Edition. Version: 7.5.472 / Virus Database: 269.8.7/830 - Release Date: 6/3/2007 12:47 PM
Be a better Globetrotter. Get better travel answers from someone who knows.Yahoo! Answers - Check it out.
Posted by louis spitz (aronella@…>)
Hi Faith,
Thanks for the respons.
Where do you attatch the halyard? Is the aluminum casting strong enough, or do you use the outhaul on the boom, or another place.
What brand of stack pack did you go with?
Thanks, Lou
Sent: Monday, June 04, 2007 12:54 PM
Subject: Re: [freedomyachts2003] lazy jacks on Freedom 35- reconfigure?
Faith
www.faithandrewsbedford.comThomas Wales <twales@adelphia.net> wrote:
Hi Lou,One way to relieve pressure on the lazy jacks to to use your main halyard as a topping life to hold up the boom after you have dropped the sail. Putting the sailcover on with slack lazyjacks is much easier. You’ll need to have something to hold up the boom. Either a rigid vang, lazyjacks or a topping lift. The main halyard as topping lift is the least expensive and it works for me.Good luck.TW F32 Anoush KoonPemaquid, MEAt 02:31 PM 6/4/2007 +0000, you wrote:>Did anyone change the lazy jack system to make it detachable?>Does the boom need the support of the lazy-jacks when the sail is>lowered?>It’s a real pain to put the sail cover on, with the lazy jack ‘cut->outs’.>I was also thinking of the ‘mack-pack’ or ‘stack pack’ system.>Thoughts and experiences most needed and welcome.>Thanks,>Lou>F35 ‘Ripple Effect’ #23>>>>No virus found in this incoming message.>Checked by AVG Free Edition.>Version: 7.5.472 / Virus Database: 269.8.7/830 - Release Date: 6/3/2007 >12:47 PMNo virus found in this outgoing message.Checked by AVG Free Edition. Version: 7.5.472 / Virus Database: 269.8.7/830 - Release Date: 6/3/2007 12:47 PM
Lou,
I’m not a big fan of the stack-pack and similar systems.
Buy yourself a rigid boom vang and have Garhauer make a collar to go
around your mast. At that point the lazy jacks aren’t needed to support
the boom. You could convert to retractible lazy jacks like ez-jax which
is a nice system.
— In freedomyachts2003@yahoogroups.com, “rocclear” <aronella@…>
lowered?
outs’.
Lou
Dave,
Thanks for your reply.
I do have a solid vang. As my sailcover is shot (and constructed with the most awkward accomodation of openings and closures for the lazy jacks),
I thought to investigate several options: (1) a new sail cover without the lazyjack openings (2) stack pack , or (3)mack pack.
Where can I find out more about ez-jax?
Lou
Sent: Sunday, June 10, 2007 7:18 PM
Subject: [freedomyachts2003] Re: lazy jacks on Freedom 35- reconfigure?
Lou,I’m not a big fan of the stack-pack and similar systems.Buy yourself a rigid boom vang and have Garhauer make a collar to go around your mast. At that point the lazy jacks aren’t needed to support the boom. You could convert to retractible lazy jacks like ez-jax which is a nice system.— In freedomyachts2003@yahoogroups.com, “rocclear” <aronella@…> wrote:>> Did anyone change the lazy jack system to make it detachable?> Does the boom need the support of the lazy-jacks when the sail is > lowered?> It’s a real pain to put the sail cover on, with the lazy jack ‘cut-> outs’.> I was also thinking of the ‘mack-pack’ or ‘stack pack’ system.> Thoughts and experiences most needed and welcome.> Thanks,> Lou> F35 ‘Ripple Effect’ #23>
Gentlemen,
The benefit I appreciate the most from my lazy-jacks is when I
need to drop that big main in a hurry in 20 kts of wind and have it mostly
contained on the boom. Having sailed for years without them, I wouldn’t do
without them. A properly designed sailcover should not be too difficult to
use with slackened lazy-jacks. Just my humble opinion.
TW F32 Anoush Koon.
At 08:14 AM 6/11/2007 -0400, you wrote:
Dave,
Lou
To:
<mailto:freedomyachts2003@yahoogroups.com>freedomyachts2003@yahoogroups.com
Lou,
is a nice system.
— In
<mailto:freedomyachts2003@yahoogroups.com>freedomyachts2003@yahoogroups.com,
lowered?
outs’.
Lou
Version: 7.5.472 / Virus Database: 269.8.13/843 - Release Date: 6/10/2007
1:39 PM
Attachment: (application/octet-stream) 28c5bc4d.jpg [not stored]
Attachment: (application/octet-stream) 28c5bcca.jpg [not stored]
Version: 7.5.472 / Virus Database: 269.8.13/843 - Release Date: 6/10/2007 1:39
PM
Here’s the website for EZ-JAX - http://www.ezjax.com/
A good canvas person could probably come up with a better designed
cover. I don’t like any of those cover systems that require
attachment to the sail but obviously a lot of people have them and
love them. Just personal preference on my part.
— In freedomyachts2003@yahoogroups.com, louis spitz <aronella@…>
Dave,
lazy jacks),
Lou
reconfigure?
Lou,
go
support
which
is a nice system.
— In freedomyachts2003@yahoogroups.com, “rocclear” <aronella@>
is
lowered?
jack ‘cut-
outs’.
Lou
The stack pack doesn’t require any attachment to the sail. The sail is made
loose footed and the cover goes into the track on the boom. There are two
big advantages for a 35. First, since you don’t take the sail cover on and
off, there is less work and no storage issue for the cover. Second, when
you drop the main, you don’t need to jump up and tie the main with sail ties
or remove them when it’s time to raise the main. One other point. When I
drop the main the reefing lines don’t hit my wife in the head anymore.
That’s a good thing.
Jay
Date: Mon, 11 Jun 2007 16:02:31 -0000
Dave,
lazy jacks),
Lou
reconfigure?
Lou,
go
support
which
is a nice system.
is
lowered?
jack ‘cut-
outs’.
Lou
Need a break? Find your escape route with Live Search Maps.
http://maps.live.com/default.aspx?ss=Restaurants~Hotels~Amusement%20Park&cp=33.8\
32922~-117.915659&style=r&lvl=13&tilt=-90&dir=0&alt=-1000&scene=1118863&encType=
1&FORM=MGAC01
My friend just told me he had this done to
his F35 and loves it. I have seen it in action on a Bristol and it works very well!
http://www.northsails.com/North_America/cruising_sails/QuickCover.htm
Bob
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of Dave_Benjamin
PM
Lou,
is a nice system.
lowered?
outs’.
Lou
I’m very happy with my 2 mack packs (and
I have boom kickers in place of rigid vangs) on my 33.
One thing I’d recommend is don’t
attach the bottom two sets of twist locks to the mast like they normally do.
Just have the front made wrap around or use bungee cord. They its easier if you
want to lower it while sailing then securing the front part and you avoid extra
rivets in the mast or if you forget to undo the twist locks on certain points
of sail they can break from the tension. The upper hooks are not a problem.
Please consider joining/moving from this
group to Freedomownersgroup where we can prevent spam etc.
Alan
freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of louis spitz
Sent: Monday, June 11, 2007 8:14
AM
To:
Dave,
lazy jacks),
pack.
Lou
2007 7:18 PM
Subject:
Lou,
is a nice system.
lowered?
outs’.
Lou
Alan, how do I join the Freedomownersgroup?
Louis
Sent: Wednesday, June 13, 2007 9:58 AM
Subject: RE: [freedomyachts2003] Re: lazy jacks on Freedom 35- reconfigure?
I’m very happy with my 2 mack packs (and I have boom kickers in place of rigid vangs) on my 33.
One thing I’d recommend is don’t attach the bottom two sets of twist locks to the mast like they normally do. Just have the front made wrap around or use bungee cord. They its easier if you want to lower it while sailing then securing the front part and you avoid extra rivets in the mast or if you forget to undo the twist locks on certain points of sail they can break from the tension. The upper hooks are not a problem.
Please consider joining/moving from this group to Freedomownersgroup where we can prevent spam etc.
Alan
From: freedomyachts2003@yahoogroups.com [mailto:freedomyachts2003@yahoogroups.com] On Behalf Of louis spitzSent: Monday, June 11, 2007 8:14 AMTo: freedomyachts2003@yahoogroups.comSubject: Re: [freedomyachts2003] Re: lazy jacks on Freedom 35- reconfigure?
Dave,
Lou
Just click http://groups.yahoo.com/group/FreedomOwnersGroup/
and request to join. You’ll get a confirmation once one of the
moderators confirms you’re a valid person based on your message rather
then automated junk mail.
Alan
11:38 AM
To:
Louis
13, 2007 9:58 AM
Subject: RE:
Alan
AM
Dave,
Thanks for
your reply.
I do have a
I thought to
Where can I
Lou
reconfigure?
Lou,
is a nice system.
lowered?
outs’.
Lou
